What do you guys do with your KDX battery in the winter?
edog600
Post by edog600 »
Should it be disconnected, pulled out and brought inside, thrown on a charger once in a while? Thanks guys
Has thanked: 5 times
Been thanked: 12 times
What battery?
turtle
Post by turtle »
Yup, mine is missing!
Edit: now I understand!
Bill
Central IL
2004 KDX220R
2011 Triumph Tiger 1050 SE
Frysk
Post by Frysk »
I think he owns a SR model.. ?
All I know is that the normal KDX's E and H series don't have battery's
KDXsg
Post by KDXsg »
not even with the SR model. I own one.
A true KDX customizer!!
Rjcapt
Post by Rjcapt »
A battery may have been added if it was ever made street legal, for the added electrical capacity needed for the additional lights.
Generally speaking, batteries should be maintained at full charge if subjected to below freezing temps. You can either:
Fully charge the battery and store in a warmer place (in the house, etc)
Charge the battery once a week or so by running the engine or using an external charger
Or, (what I do) put a trickle charger such as a "battery tender" on it and forget about it. I have a bunch of them, they are cheaper than new batteries every year....
Pete
Rjcapt
Post by Rjcapt »
An additional thought
The lower the charge on a battery, the more susceptible it is to freezing. Once it freezes, it's wasted. Also, the lower the temperature of the battery, the less current is available. That's why batteries have a CCA (cold cranking amps) rating on them. Once you start talking seriously cold (-20 or so), keep it warm even if fully charged.
And one more.
On a standard lead acid battery, always charge it in a well ventilated area, it produces noxious and very flammable fumes while charging. And a dead battery has explosive potential.
remove, bring inside, put on trickle charger.
edog600
Post by edog600 »
Previous owner made it street legal so that explains it. Thanks
