Hi all,
I stupidly snapped one of the four studs (lower right) on the left fork that holds the axle plate in place. There are not enough threads left to get 2 nuts on it to try and get it out. Any ideas?
Thanks
Broken stud help
Option 1: If you have access to a welder place a larger nut over the broken stud and weld the nut to the stud. if the stud is broken off flush with the surface place a flat washer centered over the stud and weld washer to stud. Now you have a large enough surface to weld a nut to the washer. Allow time to cool and spin the stud out.
Option 2: grind broken stud flush to surface, center punch stud, drill small pilot hole and extract with extractor. this will be pretty tough because the stud is of such small diameter.
Option 3: Fork conversion
Hornet
Hornet
2003 kdx 220 plated
2001 klx 300r
2004 crf 250x plated
2001 klx 300r
- Varmint
I got the piece out tonight. Used vise grips and came out after I ground a bunch of nuts trying to get both to grab the little threads that were left. I did pick up some m6 studs from napa but they wont work -the smooth length of the stud is too long. i'll try to get the right size tomorrow and if not I'll hit you up Varmint - Thanks!
- Varmint
Varmint,
Thanks for replying to my PM and also posting the stud part number here for the benefit of anyone else who may need it.
You guys here at KDXrider and the folks at TT are an outstanding source of information.
It also looks like the 172G0622 part number has been superceded by part number 172BA0622. At least that is what I found when I googled it and found it on the Ron Ayers website.
Here is a link:
http://www.ronayers.com/Search/N/687/Pa ... /Source/KA
Here is a link:
