When taking the right side engine cover off, I ran into a few issues. I'll break it into three questions:
QUESTION 1:
Right after I took the right cover off, I went to lay it down. When I laid it flat the exhaust valve advancer fell out. I didn't know it was in there. A small flat washer also fell out.
I believe that washer is part of the kick start assembly. I think it is part
92022C
http://www.motosport.com/dirtbike/oem-p ... -MECHANISM
Do ya'll agree ?
QUESTION 2:
When taking the clutch out, I inspected this center bearing:
The clutch pusher holder that the bearing is pressed in to spins freely in the larger aluminum housing but......when I squeezed on the inner sleeve of the bearing:
and tried to spin it, It felt like there were a thousand little ridges the bearing was rolling over. Make sense? It didn't spin smooth.....it spun with a bunch of small, soft "clicks" in it.
I wonder if the bearing is going out?
QUESTION 3 :
Inspected the clutch basket. It had grooves in it:
I've never had to file a basket before.
It it time too?
If so, do you just file the grooves till they are just smooth?
I've never had to replace a basket either.
From looking at the basket, there are gears riveted to the back of it.
If I have to buy a new basket, do the gears come already attached to the back?
Question 1, 2, 3
Thanks for your thoughts guys
