chainguard
Posts: 5 Joined: 09:00 pm Nov 28 2011
Post
by chainguard » 12:35 pm Nov 29 2011
She stopped while riding like it fouled a plug. Spewed a little oil from the case breather tube. Now she runs in reverse. Kick start or bump start, same. Spins the tire backwards. Most wierd. I cant be only one in the history of KDX. It ran flawless for the last five years.
Thoughts where to begin? Tranny problem?
Chainguard
doctord23
Posts: 323 Joined: 01:29 pm Jul 28 2009
Post
by doctord23 » 01:17 pm Nov 29 2011
Flywheel key or timing.
My Team Green:
2002 KX-KDX 220
2000 KDX 220
2003 KLX 300 DS
1988 White KDX 200C3
1984 KX500 (original owner)
1996 Honda Magna V4
2017 Honda Africa Twin DCT
gsa102
Posts: 453 Joined: 12:33 pm Aug 16 2011
Post
by gsa102 » 01:30 pm Nov 29 2011
I agree, most likely the Flywheel key. A 2t engine can run backwards if you change the spark timing.
96 KDX 200, 09 YZ 250
Posts: 1690 Joined: 10:06 pm Oct 22 2009
Been thanked: 1 time
Post
by Slick_Nick » 01:37 pm Nov 29 2011
Flywheel Key.
chainguard
Post
by chainguard » 01:47 pm Nov 29 2011
Thanks. I will look and see. Do I need a special puller?
Chainguard
Posts: 5893 Joined: 07:53 pm Nov 07 2008
Has thanked: 5 times
Been thanked: 12 times
Post
by Julien D » 02:55 pm Nov 29 2011
Yes, you'll need a flywheel puller. I got mine on ebay, but any parts store should have them. It's 27mm x 1.0 LH thread.
Going to move this to the E series section :).
J.
chainguard
Post
by chainguard » 03:04 pm Nov 29 2011
what is the cut off for E and H series bikes?
Chainguard
Posts: 3168 Joined: 06:07 pm Apr 27 2010
Post
by rbates9 » 04:38 pm Nov 29 2011
chainguard wrote: what is the cut off for E and H series bikes?
95-06 = H
89-94 = E
chainguard
Post
by chainguard » 04:41 pm Nov 29 2011
final question, mine has the inverted forks, 94 or 95?
Chainguard
Post
by Julien D » 04:45 pm Nov 29 2011
93 or 94.
chainguard
Post
by chainguard » 04:47 pm Nov 29 2011
any reason the inverted forks were only short lived?
Chainguard
Post
by Julien D » 05:53 pm Nov 29 2011
Not sure. Those particular forks were really not an improvement over the conventionals. Same internals, just flipped upside down. Perhaps a little less flex and obviously less underhang. They couldn't make the kdx TOO good, else they would have lost sales on the KX, lol. Someone had thrown a set of 94 USDs on my 89 before I got it. They worked well on the single track, but made me nervous as hell trying to ride fast on open trails.
Terrence Sprocket
Posts: 78 Joined: 03:46 pm Feb 14 2012
Post
by Terrence Sprocket » 06:12 pm Feb 15 2012
As far as your KDX running backwards, buddy of mine had the same prob with his old IT 175. Turned out that the stator plate shifted off timing. Which is weird cause it didn't move that much. Wouldn't think thatit would make it run backwards. Just make sure the timing marks are In sequence. Good luck!
KDX ALL THE WAY!
dfeckel
Posts: 644 Joined: 07:46 am Nov 09 2009
Post
by dfeckel » 02:39 pm Feb 16 2012
So, how can the kicker start the engine in reverse? I would think it could only if it gave a major kick-back when it started.
David Eckel
Post
by Slick_Nick » 06:01 pm Feb 16 2012
Exactly. As soon as it "catches" the engine kicks back the other way.
