Bean oil? ---does it make your plug black?
Posted: 12:32 am Nov 20 2011
by Deseret Rider
I think my bikes are jetted correctly----they run strong everywhere in the RPM range---and with 40 years of experience riding two strokes I am confident that I am not running an overly rich mixture. However, this is the first time I've ever run bean oil premix---and the porcelain around the center electrode is showing a (dry) black coloring---not a light chocolate brown as I believe is usually the goal??? So my question is:
Does bean oil turn the plug black----and is there any worry that the plug will 'foul' because it is so black?
Posted: 06:59 am Nov 20 2011
by factoryX
I may get shot by this, but my KDX fouls plugs at 40:1 with r50 Klotz unless its ridden like a 125 motocrosser. I've read similar issues on the web as well. Bean oil is good on parts, but very messy, and unless you're riding your bike like a 125, not totally necessary.
Posted: 12:34 pm Nov 20 2011
by OLHILLBILLY
factoryX wrote:I may get shot by this, but my KDX fouls plugs at 40:1 with r50 Klotz unless its ridden like a 125 motocrosser. I've read similar issues on the web as well. Bean oil is good on parts, but very messy, and unless you're riding your bike like a 125, not totally necessary.
Klotz R50 ain't bean oil, it's a full synthetic that has an additive to make it smell somewhat like castor. If your fouling plugs with R50, it's the normal 'ol jetting problem.
To the OP, if your using a real castor oil, having a black insulator on your plug is probably normal. Castor, though heaven for your bottom end, is a high ash, messy oil.
Posted: 07:10 pm Nov 20 2011
by factoryX
I thought it was castor oil, oops. And no, any other oil and it runs clean. I can't run 32:1 with R50. At 40:1 its still iffy to ride trails. Do a google search, and I am not the only who's had issues. This oil is thick.
Posted: 09:06 pm Nov 20 2011
by MadMax
R50 is meant to run 50:1. I ran it for years at that ratio with no problem until recently. It doesn't seem to like alcohol. I now run Super Techniplate and Lucas additive due to not being able to find gas without alcohol. My bikes now run better and cleaner than ever.
Posted: 11:19 pm Nov 20 2011
by factoryX
That would make sense as to why my 250r went about 2 years ago. I currently run ethanol free premium with r50, now I have a reason to do so.
Posted: 11:44 am Nov 21 2011
by jbowens2401
run amsoil interceptor at 40:1, get your jetting set to that ratio, and never look back. castor oil protects very well, but doesnt burn clean at all. its good in a screamin 125 thats torn down often for a new top end. just MHO
Posted: 11:47 am Nov 21 2011
by OLHILLBILLY
I used R50 at 40:1 with no alky pump 91 for almost 3 years. Plunking around on trails.. never fouled a single plug. Exhaust valve wasn't overly gummy when I did the top end last summer either. Dunno.
Only time I've ever had plug fouling problems was when the main jet block gasket started leaking last spring. Fixed that during the RB mods.
Switched to Amsoil Interceptor now because it costs half as much as all the main stream pre-mix oils. Can't really tell much, if any difference other than the lack of the cool smell, and the extra $$ left in my pocket.
Posted: 05:43 pm Nov 21 2011
by MadMax
The cool smell is worth the $$.. Especially if you ride cleanup in your pack.
Posted: 06:33 pm Nov 21 2011
by rattlesnake_06
+1 on the amsoil!!!
