89 200 water pump
Posted: 02:15 pm Aug 29 2011
by 89kdx200ME
hey just got a 89 kdx 200 runs great don't know alot about dirt bikes just getting into it did drain the coolant and noticed that the fin in the pump if you pull on it the shaft moves in and out a little is this normal? moves maybe little less that 1/4 inch does not wobble or anything its smooth free spinning.
Posted: 02:54 pm Aug 29 2011
by Fletch
yes they move a bit. mine moves about 1/8 .
It shouldn't free spin unless the cover behind the impeller is off. There is nothing to hold the impeller on other than the bolt torque
Posted: 03:26 pm Aug 29 2011
by 89kdx200ME
thanks just didn't want to have any problems with it took it for 4 hr ride the other day and did not seem to have any problems and seems the impeller rubs the cover its all shinny no big gouges just rubbing a little is that normal?
Posted: 04:30 pm Aug 29 2011
by Fletch
mine had the same
just make sure the blades arn't bent if you want to get really fussy.
btw there is a 10mm bolt under the water pump to drain the system. No need to remove the cover.
Have you read about the kips issues for this model (same year as mine btw). Just run a good oil (amsoil interceptor in mine 40-1) and make sure your piston is in good shape.(they last long though) I didn't and had to replace alot of stuff when mine let go.
Other than that these are really good engines that last a long time and have lots of torque, Enjoy.
