Page 1 of 3
pipe ... (sigh)
Posted: 03:10 pm Aug 10 2011
by KDX Butterfly
how do i know what kind of pipe i have on my bike? should i consider replacing it ... no problems with it ... just wondering.
and, how can i get the spooge out??!! my pink little tail is officially BLACK!!
(bandana tail that is attached to my rear fender, guys
Posted: 07:43 pm Aug 10 2011
by KDX Butterfly
a li'l help would be nice here ... hello??!!
Posted: 07:50 pm Aug 10 2011
by SS109
I think Fuzzy said you have a DG pipe on your bike.
I normally don't worry about spooge build up in my pipes. It sounds like the real problem is that your bike might need to be re-jetted.
Posted: 08:07 pm Aug 10 2011
by rbates9
The pipe should have some makers makers mark on it. Spooge is spooge. You can get the bike to run great and still have spooge. Like SS109 said it is probably a jetting issue if it is that bad.
As far as getting a new pipe, if yours is still there and not caved in then it should be good to go!
P.S. The pink tail is GREAT but any thing behind the silencer is pron to darkening.
If you are looking to clean the pipe out to start fresh then you need to pull it off and use a solvent to get the crap out. I clean it then burn it out myself.
Posted: 08:12 pm Aug 10 2011
by KDX Butterfly
burn it?
it is a DG and has a small dent, but that's it.
Posted: 08:36 pm Aug 10 2011
by rbates9
A small dent after the first 8-10 inches is no big deal.
Burn it? Yes I clean it with parts cleaner solvent and dump it out but there is still a bit left in there. I spray some brake cleaner in there to help it light then touch it off with a propane torch a few times until it stops lighting. Seems to work well for me.
Posted: 08:42 pm Aug 10 2011
by KDX Butterfly
thanks. i will give that a whirl tomorrow. will let you know how it goes. appreciate the help!
after i get done doing something with all these darn tomatoes!!! :)
Posted: 09:13 pm Aug 10 2011
by rbates9
Be careful!!!!
Posted: 09:14 pm Aug 10 2011
by KDX Butterfly
rbates9 wrote:Be careful!!!!
no ...
Posted: 06:46 am Aug 11 2011
by Julien D
Don't use a torch on the silencer. or at least, not until after you take it apart and remove the packing.
Posted: 07:06 am Aug 11 2011
by KDX Butterfly
juliend wrote:Don't use a torch on the silencer. or at least, not until after you take it apart and remove the packing.
ok.
Posted: 07:31 am Aug 11 2011
by SS109
Yes, be extremely careful! Read this first!
http://kdxrider.net/forums/viewtopic.php?t=7771
Posted: 07:43 am Aug 11 2011
by KDX Butterfly
yeah. i've read that a couple of times, but thanks for the reminder!
Posted: 08:20 am Aug 11 2011
by fuzzy
Previous owners maxima727 stuck in there.
Posted: 12:37 pm Aug 11 2011
by KDX Butterfly
I don't think I want to get into unpacking and repacking (?) a silencer just yet. Think I will just stick with cleaning the pipe.
Posted: 12:53 pm Aug 11 2011
by dan46n2
I repacked a silencer a few weeks ago... It was actually very simple.
Remove 3 bolts, slide off cover, remove packing, replace packing, slide cover back on, insert 3 bolts.
I think it'd take more time to try to burn out the carbon in the pipe! And more dangerous too! ;)
Seriously though, if you try repacking the silencer then I'd like to recommend staying away from the 2stroke "performance" packing (the pink stringy stuff) and get the sheet/roll style packing instead.
The repacking steps were easy, but getting as much of the pink stringy packing around the insert was semi time-consuming and frustrating.
It would have been a cake walk if I had the sheet/roll style material instead.
Posted: 12:58 pm Aug 11 2011
by Mr. Wibbens
KDX Butterfly wrote:I don't think I want to get into unpacking and repacking (?) a silencer just yet. Think I will just stick with cleaning the pipe.
Might as well just put it back together then
Cleaning without a repack aint gonna do SQUAT!
Posted: 01:01 pm Aug 11 2011
by Mr. Wibbens
I don't use any cleaners
Just take it apart and lay the parts out in the driveway
Get em red hot with my mapp gas torch and let em clean themselves
After I'm all done I spray the aluminum assembly with carb cleaer and wipe it down
Posted: 01:06 pm Aug 11 2011
by Mr. Wibbens
Seriously?
Why is that?
I've been using Silent Sport (its not pink) for about 7 years. One bag will last at least 3 - 4 packings. It is super easy to use
Posted: 01:09 pm Aug 11 2011
by fuzzy
Unfortunately the packing is all filled with spoo, and it'll keep coming out for ages...If you have the pipe off and all, might as well do it all. Does that thing still have the RADvalve reed cage on it?
