Fmf turbine core
- spaun
Fmf turbine core
Ok so I got my parts and went to put them on my 93 kdx 250,turbine core and a fatty pipe,Here is my dilema the dang holes dont match up where the silencer mounts.I can either get the front in or the rear in but either way the other hole 1/4 -1/2 inches off.Is this normal?anyone else had this problem?
I can't speak from experience (I have never owned a KDX 250), but can you get enough distance between the subframe mount and the silencer tab to add a short piece of sheet metal with two holes drilled in it? That way you just have a tiny little hanger for the the tab that doesn't line up.
David Eckel
- Has thanked: 5 times
- Been thanked: 10 times
Sounds like they either sent you the wrong part or your KDX250 is not a U.S spec bike. Double check the part # on the silencer.
- Mr. Wibbens
something like this?
UHMW
UHMW
- Mr. Wibbens
yes sir
When I bought the bike it had a piece of aluminum mounted there and it cracked
This piece of uhmw has been on there for many years
