any bearing experts out there?
Posted: 01:04 am Jun 06 2011
In fitting my KX450 fork to the 05 KDX220, I'm considering a different way to mount the fork, but haven't found the magic solution yet.
Instead of pressing out the stem, I'd love to find the right sized top bearing so that I can keep the KX stem with the KX fork (and my KDX stem with my KDX fork).
A tapered roller bearing that's 28 x 47 x 15 mm would be the cat's ass - it would drop right in. Unfortunately, FAG and SKF don't make this size of roller bearing, likely because it's not a possible size. The stock KDX bearing is 25X47X15 mm and the KX stem is 28 mm.
I found an FAG NAO 30 X 47 X 16 needle bearing, which would fit with a 1 mm spacer between KX stem and bearing ID. But it's a needle bearing - will it hold up to axial loads? I'd also have to figure out a seal for it.
Got any suggestions where else to look?
Yeah, I know - I'll probably end up going the tried and true route, but thought I'd give it a look from a different angle.
