rear shock
brayden55
rear shock
Post by brayden55 »
i think somthing is funky with my rear shock because my bike looks like its sitting low. when i stand back the swing arm is almost flat! any help on how i can fix this?
i have pics but dont know how to upload them
Mr. Wibbens
Post by Mr. Wibbens »
When's the last time you serviced it?
brayden55
Post by brayden55 »
i havent sevices the shocks but the thing runs fantastic! just bought it about 2 months ago
1995 kdx 200 my baby
1986 klr 250
1989 yamaha blaster 200 just like the kdx
1983 kl 250 bought the thing for $100 it wont die
brayden55
Post by brayden55 »
i was just wondering if it is set wrong or if there is a way to raise it. im looking to go riding the weekend and would really appriciate the help thanks
1986 klr 250
did you set up your sag properly?
brayden55
Post by brayden55 »
sag??? is that those spinning rings on top of the spring?
1986 klr 250
brayden55 wrote:sag??? is that those spinning rings on top of the spring?
they are used to set your sag by compressing your spring more or less. do a search in the suspension section, you should get the procedure.
brayden55
Post by brayden55 »
alright thanks a lot
1986 klr 250
Has thanked: 5 times
It also helps to have the correct rate spring for your weight. Setting the sag might make your bike stick up/squat in the rear with the wrong spring.
brayden55
Post by brayden55 »
so just to make sure were on the same page if my bike looks like its sagging under its own weight then i need to back off the shock right?
1986 klr 250
Mr. Wibbens
or more likely your shock is blown , or your spring is sprung :wink:
brayden55
Post by brayden55 »
well its not compleatly saging
what do you think
1986 klr 250
Like Wibby said, "...likely your shock is blown , or your spring is sprung" or maybe someone installed some lowering links. BTW, have you disassembled all the linkage to lube it and inspect it for wear?
brayden55
Post by brayden55 »
no i havent inspected the suspension at all except the front fork seals. is there a cheap way to fix this or do i need to buy a new shock?
1986 klr 250
Mr. Wibbens
get a manual and rebuild it yourself, if needed
Get those linkages cleaned and lubed soon. It is one of the few areas on a KDX that does need some regular servicing.
As for fixing it cheap, well, that depends on what is wrong with it. If you don't have the know how on how to diagnose it then I suggest taking it to a reputable suspension guy to take a look at it for you.
brayden55
Post by brayden55 »
i just raised the bike on a lift and tightend the shock a couple more turnes and it seemed to raise the swing arm to the point where it looks normal and feels better. i think i will still need to fix it in time but it should be fine for this weekend :grin:
1986 klr 250
