don't know why the PO bought an H-series muffler, I'll more than likely end up selling it
Sweet, you should post some pics when you're done! The valve itself and the gear on mine are fine, it's only the little stem on top that broke off. I was thinking the same about using JB weld and how well it would hold up against heat and vibration. I've had bad luck with JB weld 75% of the time so I'm debating on whether I wanna put that stuff inside my motor or notdfeckel wrote:Nice to see another E saved from the boneyard :)
I'm doing the exact same thing on a '93 KDX right now. I bought it as a basket case for parts, but realized that with some effort and a few more parts, it would be a runner. I'm going to get it together and give it to my bike-less buddy.
I hope your KIPS valve replacement goes well. The sub valves on mine were TRASHED. The right side was completely missing, with the bushing dropped down into the valve bore, and the left sub valve was half gone and what was left was rounded off and polished like a marble. Almost unrecognizable. The sub valve bores are so worn that I probably won't bother putting any new sub valves in. I might make something to partially block the ports to regain some bottom end, at the expense of some top. I wonder how temperature resistant JB Weld is...
Lower journals? I havn't taken out the valve assembly completely, but it looks like they're fine to me. Nice and clean, and tight. I assume the PO re-did the KIPS when he overhauled the cylinder and pistonjuliend wrote:
Make sure the lower journals are fairly tight. If they are much too loose, use a punch on 4 sides close to the journal edges. This will close up the hole a bit, and help it seat more securely. if you go to far, you will need to drill it back out. Replace the set screw on the RH guide bushing with a collar that holds it more securely. Just a little movement there can bind/break valves.
E-1's are great bikes! You should restore it if it won't cost you too muchFletch wrote:I had left hand valve closed and right and center working and the power was decent at low end and just fine up top.
I have an 89 as well and all the things good on your bike are bad on mine! Except my kickstarter worked. Now I am contemplating doing what you're doing or just moving on to something else.....
My best guess would be from broken piston rings before the brand new top end. And nah, the piston, rings, and cylinder sleeve are all brand new. The PO tried buffing and polishing out as much of the dings as he could but they still show.TWMOODY wrote:What are all the little dings from in the head ?
Does the top of the piston have the same marks ?
