2001 cr125 Donor
Posted: 03:31 pm May 09 2011
by Carone
I found a great deal on a 2001 cr125 roller that I plan on swapping a kdx 200 motor into. It looks like most builds use an 03 or newer swingarm. What needs to be done to the earlier swingarms to make them functional for a hybrid?
Posted: 03:40 pm May 09 2011
by market
hi, check this....
http://www.dirtrider.net/forums3/showth ... p?t=162382
kdx 200 engine and cr125 2001 frame.....
:wink:
Posted: 03:54 pm May 09 2011
by scheckaet
don't know if it'll matter or not BUT this was an E serie 200 (pre 95)
Posted: 07:49 pm May 26 2011
by Carone
These are perfect thanks.
How are people cutting down the swing arm bushings? Machining or cutting?
Posted: 09:38 pm May 26 2011
by scheckaet
grinder with cutting wheel. then finished it with with a file to make it perfectly flat. Check the hybrid builds, it's been detailed a few times.
Posted: 04:14 am May 27 2011
by factoryX
Is this year worth doing? Whats the handling like compared to a 03+ kx125 hybrid or a 02+ cr125 hybrid?
Posted: 07:12 pm May 27 2011
by Carone
Yes, the 00-01 are second gen frames and are comparable to 02+ frame. Honda had issue with the pre-00 first gen frames
Posted: 09:21 pm May 27 2011
by chopper
FYI,if you use the Gen II (00-01) frame you can easily update the styling to the Gen III(02-07). You need the Gen III tank and airbox along with some simple brackets fabricated then you can mount up the Gen III plastic for a more modern look.
Posted: 10:45 pm Jan 19 2012
by kawabunga
Hey Carone-looks liked nobody addressed your question.
FRom what I can tell, it looks like Legend boy just cut the 2001.
Where did you see a 2003 swingarm used?
