Stupid mistake...broke stuff
Posted: 06:13 pm May 07 2011
I managed to break several things on my KDX today...and this was on the stand in the garage....
I had both wheels off to change tires and the bike was on the stand. I hadn't ridden it for a while so I thought I'd start it up for the hell of it.
I opened the choke and gave it a couple of kicks and it fired right up. Then my brain must have shut off because I forgot to close the choke and it started to rev up really high, I hit the kill switch but it wouldn't stop the engine. Then I decided to do what I usually do when it's revving for the moon and the plug is too hot for the kill switch to work...kick it in gear, drop the clutch and stall it. Only this time since I had the rear wheel removed when I dumped the clutch my chain wrapped around the front sprocket mashing my shift lever down and wedging between the sprocket and swingarm. Several things got broke but the things that concern me are: 1. the force of the chain being wedged between the sprocket and swingarm broke the engine case where the swingarm bolt goes through and 2. the shift lever was forced down way past it's normal position and I can't get it to move back up. This looks like a really expensive and/or time consuming mistake to have made. Can anyone tell me 1. can the engine case be welded and will it be strong enough and 2. what may be bent/broken in the gearbox and should it be easily replaced?
I sure do feel like an idiot for this one....
Any help would be great
