White smoke
Posted: 06:24 pm Apr 26 2011
by JoKDX220r
I'm putting my bike all back together,
I'll soon post pics of it now with black frame, I also polished and painted the swingarm.
Yestarday when I removed my carb to change jetting ( after the engine warmup ) I noticed a small shot of white smoke getting out of the cylinder, just enough to see it, I also noticed the same "white smoke" out of the silencer after I stop the bike...
I searched the forum about coolant leaking from the head/cylinder, but the exhaust smoke is as "blue" as normal, and smell like good 2stroke smoke, the plug smell also good no coolant there...
The plug had a white circle around the "tip", that's why I changed the jetting..
is running too lean can make this kind of smoke or is everythings ok ???
Thank you!
Posted: 07:37 pm Apr 26 2011
by scheckaet
http://www.kdxrider.net/forums/viewtopic.php?t=1156
not sure what you mean by tip, so (re)read the jetting guide.
smoke could be exhaust leftover in the expansion chamber maybe?
Posted: 08:41 pm Apr 26 2011
by JoKDX220r
Thanks for your answer scheckaet, Yes I alerady read and re-re-re-read the jetting guide, by tip I mean the center electrode of the spark plug.
The exhaust leftover may be the reason why I see this.
