gas tank insert
Posted: 06:27 pm Apr 20 2011
by kawie
i tried a seach but came up with nothing.my tank insert for rad shoud is spinning in the tank.how do i remove it.i cut shroud off an tried a flat head screwdriver behind it to hold it but nothing.sprayed with PB an waite.
while im at it im thinking about just putting a aftermarket tank on.anyone have these aftermarket gas tanks an what do you think about them.the one im looking at is a clark 3.6 gal i think.
thanks
Kawie
Posted: 07:43 pm Apr 20 2011
by rbates9
Once those little brass inserts start to spin your pretty much done. You could try to use a pointed punch on the sides of the insert to try to get it to bite into the plastic. Good luck
Posted: 07:49 pm Apr 20 2011
by Julien D
If you get it hot enough while putting pressure on it the insert will pull out of the tank. Then you can epoxy or jb weld it back in. To heat it up, use a heat gun, or put an electric drill on the bolt and just spin the hell out of it until it melts its way out of the tank. That's the only fix I know of.
Posted: 11:14 pm Apr 20 2011
by Slick_Nick
I had to do that. Pull it out, and use Epoxy to stick it back in.
Posted: 11:42 pm Apr 20 2011
by kawie
thanks guys.ill give the drill a try an reinstall with some jb or epoxy
what would be better the epoxy or jb,what kind of epoxy would
i use.ive never messed with epoxy before.
anyone have the over sized tank an what do you think of it.
thanks
Kawie
Posted: 12:02 am Apr 21 2011
by scheckaet
I think jb weld would work good enough and is less messy than the epoxy.
I may have an IMS tank for sale soon if you are interested.email me:
scheckaet@yahoo.fr
Posted: 08:25 am Apr 21 2011
by MontanaKDX
I had the same problem when I was replacing my old purple tank.
I now have the Clarke oversized tank and i love it. It fit great and you use the regular KDX shrouds. And I love having the extra fuel.
Posted: 09:54 am Apr 21 2011
by fuzzy
Prep and cleanliness is the post important part. Clean/scuff both surfaces, and rinse with contact cleaner....then allow PLENTY of time to cure....then don't overdo it when tightening.
Posted: 01:04 pm Apr 23 2011
by OLHILLBILLY
I'm dealing with the same problem now. Only it's the 2 bolts that hold the tank to the frame.
Going to grind the heads off of the bolts and hopefully get the tank pried out. Been wanting a clear Clarke for a while, looks like the final reason to get one.
