Hi all,
I wonder if it's normal, every times I install my FMF Rev Pipe, the pipe "end" didn't go all the way into the cylinder hole... it stop just after the second o-ring before the "step". The RH side of the pipe go further then the LH side..
Does a bend it the pipe I didn't notice can explain that or it is normal ?
Thank you!!
Fmf pipe install
- sped66
- JoKDX220r
I removed the pipe and silencer again, take measurements and it can't fit any better... The hole in the cylinder is approx : 15mm deep and the pipe to the "step" is around 25-30mm.sped66 wrote: If it doesn't look like it's fitting correctly, it probably isn't.
Same thing with the Fmf woods pipe.
I made some tests with my backup cylinder that also show that the pipe can't go any further.
It doesn't look like it's fitting correctly, but it is
Thank you for your anwsers !
John
