Anyone tried... (CDI)
... http://www.dragonfly75.com/moto/CDI.html
One of this guy's CDI's? 4 way adjustable and $55 inc postage!
pics are all on his website
http://www.dragonfly75.com/motorbike/CDIinstall2.html
and only been for a spin around the block, VAST improvement! top end feels amazing!!
i cant give you pics now, its strapped under the tank, atm I've got both the jumpers on, gonna give it a shot with B jumper removed on the weekend. when i take it apart ill take some pics!
top end had far more over rev, im going to try a couple different jets to make sure im at the right place, bear in mind i had the electrex coil installed, which as it has a far higher output, advances the ignition all through the rev range, good for low, bad for top. i couldn't tell you how this compares to a stock bike as mine never ran right when i got it, so all i can say is that it is a lot happier now!
for £35.02...
best bang for buck mod ive ever tried (besides opening airboxes and rejetting of course)
edit : also, stator plate is in 1mm advance position as per his recommendations
for £35.02...
The box is pretty sturdy (for what it is), i used duct tape and a little foam to pad out the frame under the tank then cable-tied the box to the frame, i sealed the ends of the box with silicone to keep the water out. 1 thing I did find was that in his instructions he neglected the ignition and kill switch wires, I can't remember exactly which wire I tee'd into (been on holiday past week) but got it working really easy!
Can't wait to bore my carb out at work Tuesday to gain some extra beanz!!!
This bike really does lick my old DRZ400S, I put an FCR39 on that, opened up the airbox, used the 'E' base gasket.... still there was no excitement, the KDX feels ALIIIIVE!!!!!!!
- scheckaet
>|QBB<[/url]
you need to clean your bike a little...moto_psycho wrote:picture of it amazingly mounted...
[img::]http://s4.postimage.org/4z4hq6hnj/image.jpg[/img]
Sold ☹ DRZ 400 SM
Sold ☹ DRZ 400 SM
I may be trying one of these out myself. I have been experiencing high speed ignition problems for quite some time now. I tried jetting leaner, thinking that I was just running very rich, and ended up going as far as a 142 main jet. The bike ran more cleanly, but I still am experiencing high rev problems. I installed a new piston/rings just last night, and thoroughly cleaned the entire top end/ power valve assembly. Things were crusty, but not inoperative. Now, everything is in great shape, and I still am experiencing a high rev misfire. My source coil did not measure up to specs (reading ~150 ohms, rather than the 250-350 specified in the manual), so I ordered a new one from Ricky Stator. I tried measuring the CDI values listed in the manual, but I could not get *anything* to read at all with my multimeter.
This misfire also gets more pronounced as the motor gets hot.
So, Thanks for this post! Given the price of this unit, and your rave review, it seems like a bargain!
2004 Dual Sported KDX200
1999 Ninja 250 (Daughter's)
- KDX Butterfly
- Queen B
If you go to the link that the OP posted, you will see exactly what is inside of it. Of great importance is the thermistor, which is a heat activated resistor, which adjusts timing as the motor warms up. Thermistors are also used in most of today's fuel gauge systems - the splashing fuel keeps the thermistor cool. This is how fuel gauges can still read fairly accurately and still allow for sloshing fuel in the tank.
I just ordered my CDI from him. Before I placed the order, I asked him if it would fit an "H" series KDX. He replied that it should work just fine, and if it did not, he would refund my money without any problems.
He (Michael) has been very quick to respond to my e-mails, and that it usually a good sign...
