FRONT BRAKE HELP NEEDED
Hi, I have rebuilt a 1990 kdx E2, I have fitted a kx125 2000 USD front end on it.
I bought a new brake hose but cannot bleed the air out of it. Despite my best efforts the lever is spongy and will pull to within and inch of the bars. I have posted on here and following advice I have tried
Standard Bleeding
Gravity bleeding
Reverse bleeding with a syringe
Pulling fluid through at the caliper end using a syringe
Bleeding using pressure (via a modified cap) from the master cylinder down.
I have rebuilt the master cylinder and done all of the above, again with no luck. The front end I used from the kx was complete and before stripping the brake was razor sharp so I did not have much faith the master cylinder rebuild would work but I could not think of anything else to do!
The bike has not been used since the rebuild as I cannot get the front brake strong enough to pass the braking efficiency test we have in the uk. It is a lovely bike and I have put soo much into it.
Now spring is here I decided to have another go, I tried again today but no joy I don't know what else to try. I really don't want to have to sell because I cannot sort the front brake but I want to ride this year!!
If anyone can help I would really appreciate it.
I have pushed the pistons back into their bores and they moved ok, bled again and still no joy - the pistons did move out so that's something I guess
Help!!!
Standard Bleeding
Gravity bleeding
Help!!!
- Mr. Wibbens
I use something similar to this, never had a problem,
hi, thanks for responding, it is the only thing I have not tried.
I could not see the difference between this and the syringe pulling it through, or for that matter a pressure feed through from the master cylinder (approx 15 psi).
I guess I might have to try one, they are £50 in the UK, might just have to do it if there is nothing else to try.
all the best
all the best
- Has thanked: 5 times
- Been thanked: 10 times
It sounds as if the M/C is not working properly IMO. How was the condition of it (bore) when you rebuilt it? Have you tried a different one? I would try finding one that matches the KX front end.
Hi,
this is the original master cylinder that came with the KX front end. The only thing I changed was the front brake line, I needed a new one not to foul the front light to make it road legal.
The m/c worked fine on the original KX set up - I got the entire front end, so checked it before I fitted it to the KDX. The only new bit was the brake line - it must be air in the line but how to get it out is beyond me!
You can always bleed the system while it is off the bike. Pull the caliper, put something between the pads to not let them push out to far, and raise it above the M/C and try bleeding it. Air is lighter than the fluid so this way you are pushing the air upwards and out and letting gravity help you. You can also tap/shake various parts where you think air might be trapped to help move it along. It is the only other way I can think of to bleed the system since you have tried all the other methods. I know it may sound crazy but it was a trick I picked up from an old rider back when I was a kid and it has worked for me before on a problem system.
- scheckaet
+1
it took me forever to get mine to work properly, I'd bleed for a while, tap, bleed more, get po'ed then walk away. do it again a few hours/days later and it finally worked after using 2 bottles of fluid.
patience is your friend at this point,
Sold ☹ DRZ 400 SM
Sold ☹ DRZ 400 SM
- Mr. Wibbens
With a mity vac it takes about 5 minutes and you are done
I always remove the bleed screw and wrap the threads with teflon tape since the vac will pull air right through the threads
Have you tried the KDX m/c ?
- rbates9
Hi Guys,
thanks for the suggestions very much appreciated. I am feeling slightly more philosophical this morning and will have another go.
I tried placing the caliper higher than the m/c last time without success, was hanging there for a few weeks as I recall as I got so di*ked off with it. However, I have not tried the tapping approach so I am thinking of using a mityvac (need to get one), on the suspended caliper whilst tapping it. If that does not work I will give up!
I have taped the threads to stop air ingress and I have tried the KDX m/c, I was not impressed with that when I bought the bike to rebuild but it was much better than I have managed to achieve with the KX m/c. I did swap it out but achieved much the same level of squishyness!!
All the best and thanks for the suggestions!
- ihatefalling
- Mr. Wibbens
Re: FRONT BRAKE HELP NEEDED
Perhaps you are expecting too much out of this brake and it is operating properly?gertie6car wrote:Hi, I have rebuilt a 1990 kdx E2, I have fitted a kx125 2000 USD front end on it.
I can pull mine to within a 1/2" to the grip
[youtube][/youtube]
Mine looks about like Wibs, maybe a bit less squishy. It will lock up on dirt with two fingers at low speeds.
For the OP, all kinds of little things can add up on a new installation like you've got. I'd get it as firm as you can and ride it a bit to set the pads in and get the hardware settled down.
- Varmint
Just out of curiosity, have you tried going back to the factory brake line?
- KDX4ID
+1scheckaet wrote:+1
CURRENT FLEET
2008 KTM 990 Adventure...Alaska here I come!
2010 KTM 300 XCW... stop me before I buy again!
2005 KDX220... single track sweetie
2007 KTM 450 EXC... my baby
2008 KTM Superduke... Canyon Carver
1996 Honda 650L... GONE but not forgotten
http://www.friendsoftruckeetrails.org
