Page 1 of 2
Bet you never thought you'd see this?
Posted: 12:22 am Feb 23 2011
by Mr. Wibbens
LOL
Check out the recommendation from the TT Off-Road Riding Expert
http://www.thumpertalk.com/forum/showth ... p?t=958740
Posted: 12:54 am Feb 23 2011
by scheckaet
he could make a hybrid kx 200 with KDX fork on it, would make the ultimate woods machine
Posted: 01:16 am Feb 23 2011
by TWMOODY
That must make my used oem KDX forks worth a mint !
Posted: 08:10 am Feb 23 2011
by Tedh98
Yeah, KDX forks were the last thing I was expecting as a recommendation.
Posted: 08:47 pm Feb 23 2011
by David_L6
TWMOODY wrote:That must make my used oem KDX forks worth a mint !
That's what I was thinking!
Posted: 11:56 pm Feb 23 2011
by SS109
OK, I have some "classic" '90 KDX forks for sale. These are
THE woods forks to have! Don't miss out on these complete, factory stock forks! Only $300!
Posted: 08:44 am Feb 24 2011
by zomby woof
Just keep this in mind the next time somebody quotes an "expert", or one tells you something
Posted: 10:58 pm Feb 25 2011
by kdxtreme
Dwight likes it oldschool everyone is different. I was hauling on mine with the stock forks but I bent them good on the third ride so I got a little sketched out about the underhang but I'm different also.
Posted: 11:33 pm Feb 25 2011
by TWMOODY
kdxtreme wrote:Dwight likes it oldschool everyone is different. I was hauling on mine with the stock forks but I bent them good on the third ride so I got a little sketched out about the underhang but I'm different also.
You need some stock forks ?
Give you a deal !
Posted: 11:51 am Mar 03 2011
by johnyblaze
While I'm not sticking up for the stock KDX forks (I have a pair setting in my garage as well) I will say that I think the advantages of USD forks in general are sometimes overblown. For instance, the DRZ400 has a great set of conventionals that can be made to do whatever you want.... and won't blow through seals twice a year. The difference is that the KDX stockers were spindly little guys that lacked the adjustability and guts required by their riders. I rode a set that had been revalved and resprung and they weren't that much better than stock. Nowhere near as good as the KX250's I later installed.
Posted: 12:52 pm Mar 03 2011
by Julien D
Yeah, the trick is getting an MX valved fork to soak up the small bumps like the stock kdx forks did though. I imagine this is going to be an easier task than trying to get the stock forks to handle any kind of big hits.
Posted: 12:56 pm Mar 03 2011
by SS109
After having my '96 forks re-valved I absolutely love them. They soak up everything yet still can take the big hits without bottoming or jarring my teeth out. The stockers were great at slow technical stuff but they were never going to handle the fast, aggressive, desert riding I do.
Posted: 01:00 pm Mar 03 2011
by Julien D
Agreed. I hope my MX forks turn out better after some work on the shim stacks.
Posted: 02:16 pm Mar 03 2011
by Tedh98
I was glad that I posted that question on TT, the advice I was given was a step in the right direction.
I went riding this AM with the changes that were suggested and the forks are much better. I'm going to try one more change on the MV to see how it works, but I think I'm close to being satisfied with these forks.
Posted: 02:30 pm Mar 03 2011
by Julien D
Good to know Ted. When I'm ready to work on my shim stacks, I will hit you up for some advice if that's cool. Did you manage to take any pics while you had the base and/or midvalves apart? I wasn't planning any changes to the MV, but if you find it helps, I certainly will. I'm in the same boat as you. I like the way they soak up landings and big hits, but on the tight bumpy single track they are pretty harsh.
My forks are 43mm KYB's, mid 90's yz250. I think the basic config should be similar. Yours are probably 46's?
Posted: 09:27 pm Mar 03 2011
by Tedh98
juliend wrote:Good to know Ted. When I'm ready to work on my shim stacks, I will hit you up for some advice if that's cool. Did you manage to take any pics while you had the base and/or midvalves apart? I wasn't planning any changes to the MV, but if you find it helps, I certainly will. I'm in the same boat as you. I like the way they soak up landings and big hits, but on the tight bumpy single track they are pretty harsh.
I'm not anywhere close to being an expert, but I'll try to help you out. I've really learned a lot just reading posts in the Suspension section on TT.
Any pictures I've taken are
here , I've got a page set-up to track the changes I've been making on the forks. I've updated that to include the changes I just tested today.
I believe my forks are 48's.
If you haven't seen this site before,
http://valvinglogic.com/index.php, it can be helpful in comparing stacks between different bikes or the same bike over different years.
Posted: 07:17 pm Mar 04 2011
by Julien D
what i've gotten kind of confused about, is which secion of shims in the base valve is the high speed stack. In that first picture where you have laid everything out from the base valve, which section relates to the high speed damping?
Posted: 07:40 pm Mar 04 2011
by Tedh98
The HS are the shims furthest away from the piston (usually the smaller shims) and the LS (usually the larger shims) are the ones closest to the piston.
Posted: 08:31 pm Mar 04 2011
by Julien D
So in this picture...
There is only one shim closest to the nut, the rest are on the other side? Or is it that small crossover shim that separates them?
Posted: 08:41 pm Mar 04 2011
by Tedh98
I wasn't thinking correctly when I replied, I'll edit that.
You are correct, the crossover shim (4th shim from the left in that picture) separates the HS from the LS. So there are three LS shims (shims 1-3 starting from the left), the crossover (4th) and the rest are the HS shims.
