Pissing 220R
Posted: 11:07 pm Jan 29 2011
Aloha guys... new owner here of a 2000 220R purchased this week.
Gas overflows from the carb overflow tube... yes, I've read a lot of threads on this problem and see it's quite common. I've cleaned the carb, reset the float level by adjusting the float to be parallel to the mating surface and frankly, that made it worse. I reset the level so the arm was just a bit lower (greater distance) and that has helped. However, I still have a slight leak out the overflow tube when I lean the bike to the left a bit more than it is when on the sidestand and stand it back up... like gas is sloshing around in the bowl and coming out the overflow tube. It doesn't do this when i tip the bike to the right. Float needle looks good with no obvious flaws.
Do I keep on lowering the float needle tang till I get it to stop pissing or can there be another cause of this problem or can this be considered normal behavior?
I have a new float and float needle on order, but I'm trying to see if I've missed something.
I've cleaned the needle seat and made sure the carb is aligned properly when it's reinstalled on the bike.
Help?
Help?
