Which wire to use for power for heated grips? Red or yellow?
Posted: 10:05 pm Jan 06 2011
Installing heated grips. I don't have a multi-meter.
Still using stock stator, so I know I won't be able to heat grips and run lights at same time.
If using the wires coming off the light switch, would I splice into the red or yellow wire to get (constant) power for the grips?
Thanks......Impart wisdom if you got it
