I appreciate it. Yes I'm planning on doing a full flush/bleed when I get my rear hydraulic switch for my brake light. I plan to clean/inspect the calipers to see if theyre sticking at all (and rebuild if necessary) The brakes just have no bite and are glazed up it seems.Goofaroo wrote: 09:41 pm Jun 01 2021 I’m glad to hear it was a simple fix.
Organic pads will perform well and generally they are the cheapest. They’re also easier on your rotors than ceramic or sintered pads. The pads below would work fine and for the money order 2 sets so you’ll have spares. If you like to spend more the EBC Kevlar pads are organic (no asbestos) and work pretty much like less expensive organic pads.
https://www.ebay.com/itm/154010498028
Don’t expect pads to solve your brake problems. The calipers need to be cleaned and the pins need to be lubed. You probably also need fresh fluid and a proper bleeding. The brakes on your KDX should be very powerful and easy to modulate. If they aren’t they need some maintenance.
Thanks for the link, theyll be here june 7
