Page 5 of 8
Re: kdx220 will not idle, heavy smoke on decel ?
Posted: 05:00 pm Apr 16 2015
by 6 Riders
Well, the part on the left is a Boyesen reed cage. The thing on the right is the stock reed cage, but you don't have the outer part (carb boot) for it. Why didn't you just order replacement reeds for the cage? Take those tiny screws out and the reeds (2 pc each side) will come off. Those are the parts that you should be replacing.
Here is the cheapest I've found them.....http://www.oemcycle.com/Item/product/900025751
Posted: 06:13 pm Apr 16 2015
by ohgood
6 Riders wrote:Well, the part on the left is a Boyesen reed cage. The thing on the right is the stock reed cage, but you don't have the outer part (carb boot) for it. Why didn't you just order replacement reeds for the cage? Take those tiny screws out and the reeds (2 pc each side) will come off. Those are the parts that you should be replacing.
the cage is chipped in the corner
Posted: 06:58 pm Apr 16 2015
by Sullyfam
My humble and possibly incorrect opinion...
The cage on the right looks like the stock setup and the left (given the sticker) looks like the Boysene replacement. I have dealt with the Boysene system, but it looks like it replaces the intake boot and cage with a single unit. I suspect that all is fine with this aluminum boot/cage so it's just a matter of checking the reeds. If they don't seal (I.e. Lay flat against the cage) then you can order new Boysene reeds.
As for the stock cage and reeds (right side of pic), not much good without the boot to attach to the carb.
by ohgood
sorry, i can't edit that post with Tapatalk.
Posted: 09:07 pm Apr 16 2015
by Sullyfam
I agree with 6 riders in that the top left corner of the cage looks like a chunk of metal is missing. If that's the case new reeds won't help as the reeds will still not seal properly. If not, then I would just go to the Boyesen website and order replacement reeds. If you are unsure which to order then call Boyesen and I bet they can help get you the correct reeds.
Posted: 10:02 pm Apr 16 2015
by KDXohio
Order a 55$ boot for the stock setup or a new 130$ rad valve from boyesen. Personally Id get the rad valve and return the stock cage
Posted: 11:05 am Apr 17 2015
by ohgood
Sullyfam wrote:I agree with 6 riders in that the top left corner of the cage looks like a chunk of metal is missing. If that's the case new reeds won't help as the reeds will still not seal properly. If not, then I would just go to the Boyesen website and order replacement reeds. If you are unsure which to order then call Boyesen and I bet they can help get you the correct reeds.
KDXohio wrote:Order a 55$ boot for the stock setup or a new 130$ rad valve from boyesen. Personally Id get the rad valve and return the stock cage
i put putty on the reed cage last night, filed it smooth, removed the excess, and flipped the reeds. it looked to be quite an improvement in sealing.
i ran the bike this morning, the repaired cage and OK sealing reed made zero difference.
i'm extremely skeptical the reeds are playing any role at all in the current poor performance of the engine.
since i've cleaned/checked/rejetted about 20 times now, the carburetor isn't a suspect either.
which leads me with .... nothing else to check, fix, or try, besides craigslist'ing the bike.
Posted: 12:28 pm Apr 17 2015
by Tedh98
ohgood wrote:it looked to be quite an improvement in sealing.
OK sealing reed
So the reeds still aren't sealing correctly?
Posted: 01:57 pm Apr 17 2015
by KDXohio
where are you located?
Posted: 02:24 pm Apr 17 2015
by ohgood
tedh -
i might could slide a .001" feeler gauge between the cage and reed, at the ends.
Posted: 02:25 pm Apr 17 2015
by ohgood
kdxohio- Birmingham Alabama
Posted: 10:09 am Apr 18 2015
by Sullyfam
I just re-read the entire posting to make sure I properly recalled what all had been done. Holy smokes! This is truly baffling. You fixed the engine seal issue so no tran fluid loss, carb, petcock and air filter all cleaned and jetting was unchanged (at least original setting was tried). So air and fuel should be reaching the intake and now you have checked the reeds and did some work to ensure they are sealing. Have you checked the exhaust system from the header all the way to the pipe? If everything is flowing as it should leading into the cylinder, perhaps it's an issue on the exit? I know you have gone through the KIPS so take that variable out, but maybe a mouse is in the house? [emoji16]
Posted: 06:32 pm Apr 18 2015
by ohgood
Sullyfam wrote:I just re-read the entire posting to make sure I properly recalled what all had been done. Holy smokes! This is truly baffling. You fixed the engine seal issue so no tran fluid loss, carb, petcock and air filter all cleaned and jetting was unchanged (at least original setting was tried). So air and fuel should be reaching the intake and now you have checked the reeds and did some work to ensure they are sealing. Have you checked the exhaust system from the header all the way to the pipe? If everything is flowing as it should leading into the cylinder, perhaps it's an issue on the exit? I know you have gone through the KIPS so take that variable out, but maybe a mouse is in the house? [emoji16]
i'll pull the pipe and see.
from today's attempts at electrical diagnosis:
two more hours wasted on the piece of ****.
40V AC at the lighting circuit, and
7.36 Ohms ( i guess, i'm not an electrician) on the Yellow to Black wire (from stator)
and
7.19 Ohms (i guess) on the White/Red to Black wire from stator.
The bike started fine the first time (like always) but then got progressively shittier and shittier until it took 10-15 kicks to get it to start again. Tried to ride around the neighborhood to watch the voltages, but it runs so completely **** right now that's not really possible.
The LED head/tail lights are working fine, but the bike runs so shitty it's pointless to try and get over 10 MPH with it to test jetting/whatever.
Any more suggestions ?
Posted: 07:30 am Apr 19 2015
by ohgood
yep, the pipe is clear. hair dryer is blowing onthe stator... but i don't expect it to make any difference.
my money is on something in the carb worn out, or the whole carb worn out.
either way, it's time with me will end the day the title comes in. to much frustration to trust all those old, worn parts again.
Posted: 08:16 am Apr 19 2015
by KDXohio
Have you checked the floot height could be dumping more fuel in
Posted: 10:18 am Apr 19 2015
by ohgood
KDXohio wrote:Have you checked the floot height could be dumping more fuel in
yes, i've checked ti about 12 times now. 16-17mm depending on the slop in the float's pivot.
this morning was testing the coils/stator with a hairdryer on it. no obvious changes. soooo , it's not electrical.
Posted: 11:17 am Apr 19 2015
by ohgood
i don't understand what the manual is saying to check, or how, so this is what i have:
and
heat doesn't make any difference. what does it mean
Posted: 06:20 pm Apr 19 2015
by Silverfox
That's K ohms you're reading, if that makes a difference.
Posted: 06:25 pm Apr 19 2015
by ohgood
Silverfox wrote:That's K ohms you're reading, if that makes a difference.
Greek or Chinese would be about the same, to me.
Posted: 07:30 am Apr 20 2015
by Tedh98
Does it always run better cold and then get worse as it heats up?
Are you in North, South, East or West part of Alabama?
