KX fork conversion recap?
Ski... I think right now I'm riding a little high in the saddle.. I am going to do a reconfigure to make up for it. It is going to be very touchy but it will work. Basically, use a washer under the top clamp and give me a little more room to drop it. I still have 1/2 inch that I can drop it without doing this, but I like the extra room.
Well... got 'er all level now! Put a washer under the top tree and dropped the forks another 3/4".... and still can adjust the forks with the clickers! Awesome.... Now that part is truely done. Thanks guys for all the help.... I can't wait to ride it after I get the topend done this weekend.
Green Hornet
Any pics regarding Fabricate a .025 shim for the slop between the upper t-clamp hole and the stem and install. Any update of any mistakes learned or adjustments to final work
2008 KLX450R
2008 DRZ400SM
2005 KDX 220R
1985 KDX 200A3
2005 KLX 125L (SONS)
2003 KTM 50SX Pro Jr
B Senior # 254/0092
Thanks to my 2008 Sponsers:
John W Read Jr
2008 KLX450R
2008 DRZ400SM
2005 KDX 220R
1985 KDX 200A3
B Senior # 254/0092
John W Read Jr
- Has thanked: 83 times
- Been thanked: 20 times
For a quick fit-test which may actually work in the real world too, grab some aluminum foil from the kitchen and cut a strip off the length of the internal diameter of the KX upper clamp's stem hole. Just fold it over about 6, 7 or 8 times until it takes up the space.
From what I have read, more people seem to be more satisfied with having a bushing / sleeve installed to take up the difference instead of a shim stock solution.
Green Hornet
Just trying to picture what it looks like. Guess I'll figure it when I have apart this winter. I like the Alum Foil idea.
2008 KLX450R
2008 DRZ400SM
2005 KDX 220R
1985 KDX 200A3
B Senior # 254/0092
John W Read Jr
2008 KLX450R
2008 DRZ400SM
2005 KDX 220R
1985 KDX 200A3
B Senior # 254/0092
John W Read Jr
Just cut a strip of aluminum foil about 3" long and 8" wide. If you fold it over 8 times, that will be about 3/4" wide, which is about right for a shim. You can try different amounts of foil, then go buy some that is "official", if you are wanting to use the shim stock idea.
OOH! Here's a picture. You know Wrigley's chewing gum, right? Just imagine taking the gum out and folding the shiny paper back to normal shape. Just picture wrapping that around the stem. It is just something to take up the extra space, which is not much to start with.
Green Hornet
Got it. I think. Mr. Wibbens Chewing Gum
2008 KLX450R
2008 DRZ400SM
2005 KDX 220R
1985 KDX 200A3
B Senior # 254/0092
John W Read Jr
2008 KLX450R
2008 DRZ400SM
2005 KDX 220R
1985 KDX 200A3
B Senior # 254/0092
John W Read Jr
- KDX220PHIL
Has anybody done this? Does anyone have the KDX stock distance from axle to tube? Would be nice to have this documented.skipro3 wrote:Hi Inda,
I...... Have you measured the front ride height before and after your fork mod? I'm thinking that the spacer might make a difference in final front end ride height.
When converting my front end I could not use the spacer under the top clamp, it would not allow my number plate to fit properly, so I used it on top like Inda's.
nykdxer
- KDX220PHIL
nykdxer
thirteen
Due to this posting and the one from tmwwody I dedcided to do this conversion as well. I am very pleased with the results and here is the link to my posting that explains the mistakes that I made and how I solved a few other isssues.
http://kdxrider.net/forums/viewtopic.ph ... learned+kx
Thanks to tmwoody for all the email support!
Byte
anyone else have the '03's in the kdx?Indawoods wrote:Well... some guy saw I was second high bidder on the 03 forks and emailed me an offer for a set for $220 shipped. I told him SOLD!!So... now I gotta figure out if I need to sell my 01 wheel and get an 03 wheel because 03 stands alone as far as suspension. From what the guy told me (He works at a suspension shop out East)...it was the most advanced system Kaw made and almost exactly like the Yamaha setups. So, there may another chapter in the KX swapout saga. In 04 they went the way of the 97-02 style via Suz/Kaw. I don't know if any of this is true, I am just passing on the info.... But I'm excited to say the least! I love a challenge!~
inda - have you validated this reasoning for the '03's being superior?
byte
KC-10ENG
Hi Everyone,
I have a question for you all. I have been trolling around reading a lot of the threads on your KDX forum and have a question. I have a 2004 KLX300R and not a KDX but the steering stem bearings are the same so I figure that all of the info should be the same.
I have purchased a couple fork sets to see what will fit on my bike. I have a 2000 KX-125 fork, wheel, caliper and triple. I also have a 2003 KX-500 fork and triple. I am almost certain that the KX-500 triple will bolt right into my KLX but which fork should I use?? I know that the KX-125 has the different fork bottoms compared to the KX-500 but are the forks internally different.
I also have a different fork combo currently installed on the bike. I have a Stroker performance fork, rear shock and linkage installed. The rear shock is 1.75" longer than the standard KLX300 to go with the Stroker linkage and rocker assy. Forks are longer by .75" So the KX forks will compliment this set up nicely.
Thanks Dennis
Thanks Dennis
KC-10ENG
http://s923.photobucket.com/albums/ad80 ... g&newest=1
Well the conversion is all done, I ended up with a complete front end of of a 2003 KX500. Thanks for all of the great threads that made me do this.[/img]
Looks wicked!
