Page 4 of 6
Posted: 10:21 am Oct 13 2010
by bmiller
Coop wrote:So what's the scoop on your cylinder. Did you decide to install the coils and use it?
Yes, I'm going to fix the rest of the threads, use sealant on the deck and I bought an entire bolt kit for it.
Posted: 07:32 pm Oct 13 2010
by bmiller
crap...
Posted: 09:44 pm Oct 16 2010
by bmiller
Well,... check this out......
Made more progress today..
http://www.phospher.com/index.php/2000_KDX_200
Posted: 10:06 pm Oct 16 2010
by ihatefalling
:supz: :supz: :supz: :supz: :supz: :supz: :supz: :supz: :supz: :supz: :supz: :supz: :supz: :supz: :supz: :supz: :supz: :supz: :supz: :supz:
Posted: 07:45 am Oct 17 2010
by Coop
I bet that side gasket is leaking.
The engine looks really good, but I can say from experience that will chip quickly. When I did the KX60 for my nephew I wish that I just bead blasted it. I think it would have stayed nice longer.
Nice work though, I am looking forward to seeing it finished.
Posted: 03:57 pm Oct 17 2010
by bmiller
Coop wrote:I bet that side gasket is leaking.
You mean you think just the cover gasket is leaking,.. right? I haven't been able to get the flywheel off yet to look at the seal--waiting on my tusk puller first.
Posted: 04:16 pm Oct 17 2010
by Coop
Yes I think the ignition cover gasket was/is leaking and that's why it got rusty. If the crank seal was leaking there would be oil in there and not rust.
Posted: 06:14 pm Oct 17 2010
by bmiller
Coop wrote:Yes I think the ignition cover gasket was/is leaking and that's why it got rusty. If the crank seal was leaking there would be oil in there and not rust.
Makes sense..
Posted: 06:43 pm Oct 23 2010
by bmiller
Rust removed, new top-end installed with all of the new parts. The engine is finally ready for installation!
man.......
http://www.phospher.com/index.php/2000_ ... 4:25pm_PST
Posted: 07:00 pm Oct 23 2010
by Coop
Looks good.
Posted: 03:03 pm Oct 25 2010
by heckler
that thing is spotless! Nice work.
Posted: 03:22 pm Oct 25 2010
by bmiller
heckler wrote:that thing is spotless! Nice work.
:supz: :mrgreen: :supz:
Posted: 06:13 pm Oct 25 2010
by TWMOODY
If the cranks seal was leaking why would oil be in the flywheel cover ??
Where do you suppose the oil would come from ??
Please elaborate.............
Posted: 06:25 pm Oct 25 2010
by bmiller
TWMOODY wrote:>|<>QBB<
The fuel mixture flows through the crankcase.
Around 1:22seconds http://www.youtube.com/watch?v=MW1jixDvUSY
I assume the fuel pre-mix. The fuel will eventually evaporate leaving the raw unburnt oil and of course the exhaust spooge from the fuel that did ignite.
Posted: 06:30 pm Oct 25 2010
by TWMOODY
I say it would be sucking air and not leaking anything .
Posted: 06:39 pm Oct 25 2010
by bmiller
TWMOODY wrote:I say it would be sucking air and not leaking anything .
I'd imagine it's 50/50. Depends on the cycle.
Posted: 07:33 pm Oct 25 2010
by Griffbones
If a left side crankshaft seal is leaking it can suck air causing the engine to rev to the moon. Often times before they get bad enough to cause uncontrolled revving, you will see signs of oil in the stator compartment.
So both items are signs of a bad crankshaft seal. Of course most bad crankshaft seals are caused by bad crankshaft bearings.
Posted: 03:14 pm Oct 26 2010
by Coop
You would be incorrect. The premix flows all around the crank and through that area, therefor if the left crank seal is bad, that oil can leak out. Checking that stator side seal is common diagnostic for checking to see of the crank seal is bad or going bad.
Posted: 05:02 pm Oct 26 2010
by TWMOODY
Well, To the point it would leak any premix one would assume that the rider would have already noticed the uncontrollably high idle and fixed it.
Then again, maybe not.
Posted: 10:04 pm Oct 26 2010
by Lutz
bmiller wrote:I just got off of the phone with Eric.
He seemed real nonchalant about the condition of the cylinder. He said the pitting is normal after an acid wash and he recommends just using a little sealant. He also said Kawasaki's material is '****' which is why he always helicoils the threads. He missed a few threads which were damaged and I'll have to do them myself.
He also said the damaged/stripped cylinder plugs where like that when he got it and he had a hard time removing them.
Also, he did send me a different cylinder. My cylinder had a sleeve installed and couldn't be bored to 225. So,... it explains a lot.
I'm not sure how I feel about the whole situation.
Is 225cc worth the pitting and helicoils? I'm feeling it is,.. what do you guys think?
I'm just catching this now. I just can't believe it...it looks terrible in the pictures. I guess if your cylinder was sleeved, you may have got a lemon - were you charged extra for a core? When Eric did mine, my cylinder came back with the OEM threads, no issues. Also no pitting issues like on your deck (well there was some pitting in the bottom of the cylinder, but that is often inevitable in replate jobs - it does depend a lot on the quality of the original casting). Mine was done in 2002; Eric was based in his own shop in Beaver Dam and US Chrome was doing the plating at that time.
Anyway, my experience with the 225 from a performance standpoint is it was TOTALLY worth it. I guess it was a plus that I also had no quality issues, and received above average service (honestly) from Eric.
