Piston and Head. How does this look?
Varmint
Post by Varmint »
juliend wrote:The RB gear looks sweet!
Yeah it does.
In my garage
2003 KDX200
2003 KX85
2005 CRF230F
2009 300 XC-W(e)
My KDX
Mr. Wibbens
Post by Mr. Wibbens »
Wiseco says Use what you normally use
I could not find any definite reason to use dino for break-in
Brian
Post by Brian »
Make sure the cylinder is clean inside (you used the Scotchbrite with WD40 didn't you?!), lube the wrist pin and bearing when you install it into the piston and put the cylinder onto the engine/piston completly dry. No oil at all (except the wrist pin). The oil mixed in the gas will coat the cylinder as soon as you kick it over. You don't want the cylinder and piston coated with oil because as soon as it fires any excess oil will load up the cross hatch pattern and slow/prevent a proper break in. Start it and ride it. Someone had a link to an article about engine break in and they said to run it hard right from the start. I've tried it several times (it's really hard to do the first time...made me cringe) and had very good luck.
Mr. Wibbens
First I've ever heard of putting it all back together dry :roll:
Has thanked: 5 times
Been thanked: 12 times
Really? Lots of people go for the dry assembly. The idea behind it is that excessive lube in the cylinder can cause premature glazing on the cylinder walls which prevents the rings from seating quickly/correctly.
Personally I think it's fine either way. I lube the ring lands and rings along with the piston pin, but I do not coat the cylinder with oil or anything else.
Brian
Post by Brian »
I've used the dry assembly many times on 4-stroke 4 and 6 cylinder engines. Lube the heck out of the bearings and a drop of oil on the cylinder skirt and fire em up. You get an engine that does not fill the neighborhood with smoke on the first start. Let it run for a minute or so at several thousand rpm and start driving.
Brian
Post by Brian »
Oops, I meant piston skirt, not cylinder skirt.
IdahoCharley
Post by IdahoCharley »
Mr. Wibbens wrote:First I've ever heard of putting it all back together dry :roll:
Use to be a school of thought that you assemble the cylinder and piston rings dry and then use an electric drill, or even a speed wrench, to turn the piston over in the cylinder 200-300 times to get the initial seal established between the rings and cylinder. This would be prior to ever feeding any mixed gas into the cylinder.
KTM 380EXC Mine
KDX 200 Mark's
TTR 125 L Wife's
KDX 200 Austin's
EC 300 Tyson's
WR430 Husky - mine
fuzzy
Post by fuzzy »
Yeah, that's for true old school 'break-ins' All we're doing here is a ring seat. Nothing else is 'breaking in'
