Page 4 of 4
Posted: 09:39 pm Aug 18 2006
by awoodman
finally got the pipe, silencer, and jets!! I just put the pipe and silencer on and started it up...sounds nice...Ill install the jets tomorrow. Is it easy to get the carb off? whats the easiest way, including draining gas?
Posted: 10:02 pm Aug 18 2006
by strider80
awoodman wrote:okay, thanks, i got the pipe and silencer and jets from frpoffroad instead
FRP is great too :grin:
Posted: 10:08 pm Aug 18 2006
by strider80
awoodman wrote:finally got the pipe, silencer, and jets!! I just put the pipe and silencer on and started it up...sounds nice...Ill install the jets tomorrow. Is it easy to get the carb off? whats the easiest way, including draining gas?
Turn off the gas and then put a rag/bucket underneath the 3 plastic drain tubes. Then undo the gas line (gas will come out) and the two hose clamps on the inlet and outlet of the carb. Then you can wiggle the carb out (this is when gas will drain out the tubes) and remove the four float bowl screws to remove the float bowl and get access to the jets. You may be able to remove the large bolt on the bottom of the float bowl without removing the bowl to get at the jets, but I have never done it that way. If you want to totally remove the carb, just unscrew the slide assembly (black plastic cap) and set aside taking care not to get it dirty.
Posted: 10:16 pm Aug 18 2006
by Indawoods
I, turn the gas off, loosen the carb clamps on both sides, disconnect the gas line from the carb, turn the top of the carb toward me, Unscrew the the throttle cable cap and remove the slide/needle assembly and let it hang there, then remove the carb body from the bike.
Keeping it as upright as possible , I the remove the bowl screws (RB allens) and slowly remove it making sure not to spill the gas everywhere and being careful not to be rough on the float. Walk the bowl over to my oil-dry bucket and dump the gas.
Now, you can turn the carb upside down on a bench and remove the main in the middle with a 6mm wrench. And remove the recessed pilot with a small long narrow regular head screwdriver.
I always do it this way so I can check the condition of the carb, check the float level. I am never in that big of a hurry to swap jets with the carb on the bike, but I have changed needle height that way.
P.S... If your throttle cable isn't already routed in front of the petcock.... route it that way upon reassembly.
Posted: 10:28 pm Aug 18 2006
by awoodman
whats the deal with the float level? What is better when you have it adjusted right? and how do you adjust it? Thanks again guys.
Posted: 10:35 pm Aug 18 2006
by Indawoods
If you have a manual... they show how to do it.
I use a machinists mm ruler to adjust. You have to hold the carb sideways and slightly up until the needle valve just seats.... then put the ruler (or they make a fancy schmancy one just for it ) on the bowl seat face and line it up with the tallest part of the float and take my reading. I go with 17mm.... 16 is spec though I think.
You make small adjustments to the tang where you needle jet rests on to get the proper height.
If the float level is right... your carb shouldn't pee and your bike won't go lean on you and it will run better in all situations except upsidedown.
Posted: 08:55 am Aug 19 2006
by awoodman
lol, alright, thanks...and how do i tell if the jetting is too lean? im going to switch from stock to a 155/45 and don't want to ruin my engine. And where is the air screw? And what is the clip position? And if it is running too lean and not smoking AT ALL, can i screw in the air screw and it will have more gas/oil and less air and run richer? Please help, thanks! AND is the stock needle in the middle position, when the bike rolled out of the factory? I havent touched it, so will it be in the middle, as of now? and how do I get to the needle, to adjust the clip position?
