An ambitious 86 200 project
Roadhazardguy
Re: An ambitious 86 200 project
Move down here eh, it was 70*F today!
Tony
1988 KDX 200
1980 KD 80
1989 ATK 406
1984 RM 500
1980 KZ 1300
2008 SM450R
1988 KDX 200
1980 KD 80
1989 ATK 406
1984 RM 500
1980 KZ 1300
2008 SM450R
GKBO
No thank you,I'm a wet coast boy born and raised,pretty damned Canadian to.At least it's not snow which I a lot of Canada it is.
86 KDX200 thread http://kdxrider.net/forums/viewtopic.php?f=119&t=13295
My other bikes:
85GS750EF,Old Yeller http://www.thegsresources.com/_forum/sh ... p?t=161477 and http://www.thegsresources.com/_forum/sh ... p?t=175660
78 GS1000 Red Skunk http://www.thegsresources.com/_forum/sh ... p?t=176156
Street bike rider playing in the dirt.
My other bikes:
GKBO
Since it seems the factory splitter is a glorified one of these I decided to give it a try.Put some heat and penetrating oil on it to help ease it out.
It worked great!Hey do you think I might have to replace this main bearing?
My other bikes:
My other bikes:
GKBO
Decided to take the tires off and really looked at the rear rim..................GRRRRRR!!!! Hope Ken at Kenco has one reasonable
My other bikes:
My other bikes:
Roadhazardguy
You could always weld it..
Tony
1988 KDX 200
1980 KD 80
1989 ATK 406
1984 RM 500
1980 KZ 1300
2008 SM450R
1988 KDX 200
1980 KD 80
1989 ATK 406
1984 RM 500
1980 KZ 1300
2008 SM450R
GKBO
I was told no by a welder at work.Don't think I'd trust that on a rim anyway.Should be able to source one here.Shipping a wheel is $$$.
My other bikes:
My other bikes:
GKBO
My air box and carb are on the way
.Had the local shop press out the rest of the crank and what was left of the bearing.Took in the wheel,he's going to look around his stash.Hoping he finds a rim or if I'm real lucky a whole wheel.A good week as I also got the wiring harrness for my 78 Suzuki GS1000
My other bikes:
My other bikes:
GKBO
I got pics and questions but Photobucket's not cooperating so you will have to wait a bit
Did go up to Kenco,they found me a brand new Exel rim someone ordered and didn't pick up.It's a 2.15 instead of the stock 1.85,I hope that won't be a problem
BTW tried PB 3 times,can't get it to go
My other bikes:
My other bikes:
- rbates9
That size difference shouldn't matter. The newer bikes have the 2.15" wheel.
GKBO
Here's the pics now that PB is playing nice
Got the crank stripped,finally.The othere bearing stayed on the crank,got a bearing separator and pulled it off.
But the nut at the end of the crank was as you can see badly stripped
Now the question.Make a spacer to bridge the gap?Or weld it up and retap for an easier to find nut?
The gap and how far the clutch nut will go on to the existing threads.
My other bikes:
My other bikes:
GKBO
I finally got the tires off the rims,actually the front was off a while ago.The rear on fought like a demon ,took 4 days to get the stupid thing off.Old and hard!In that time I got a good look at the rim,along with the pulled spokes there are at least 4 nasty cracks.All the spoke nipples have been soaking in penetrating oil for 2 days and will get another shot today.Then 1 more in a couple of days.The thing I've learned is stuff like this can't be rushed.
After much head scratching I think it might be time get a "new" crank.
My other bikes:
My other bikes:
- Has thanked: 10 times
- Been thanked: 17 times
My crank was all buggered up when I got the bike. When rebuilding, I had them re-tap the end a size smaller. I've had no trouble, so I'd recommend that route for sure. I wouldn't feel comfortable with a spacer or washers in there and the nut only on the last few threads. Also, threadlock the hell outta that one!
GKBO
Thanks Julian,have gotten the same advice 3 times.I'm iffy on whether I should save this crank or get a "new" one.Some PO sucked up some water into the case and left it there.I'm going to start a thread in Q&A about it.
I had a good day yesterday:
The box from the helpful member
arrived yesterday and so did my gasket and seal set.Front wheel bearings to.Jammer had to inspect to
And what was in the box you ask?
The airbox and
The carb with that elusive needle,you remember the one some dumb twit broke
The airbox and
My other bikes:
My other bikes:
Roadhazardguy
Nice!
Hey I think I read the the 89+ cranks will fit the C models, can anyone confirm this?
Tony
1988 KDX 200
1980 KD 80
1989 ATK 406
1984 RM 500
1980 KZ 1300
2008 SM450R
1988 KDX 200
1980 KD 80
1989 ATK 406
1984 RM 500
1980 KZ 1300
2008 SM450R
GKBO
I was going to wait a bit but last night I gave the spoke nipples a try.Not one broken or stripped out nipple
Going to ask that in my crank thread,thanks RHG.
My other bikes:
My other bikes:
- rbates9
GKBO
Yeah soda would work but I got a bag of ground walnut shells.Was going to use them for the frame but it seems they are better for aluminium than steel so I want to give them a try on the hub.
My other bikes:
My other bikes:
- Been thanked: 10 times
Yeah, walnut shells should do a good job. I have been messing with soda blasting the parts during my hybrid build and it works ok on hard, non-rust deposits, but you definitely have to scrub off any soft stuff or it just sticks to it and makes a mess. I have some glass bead media, but will be interested to hear how the walnut shells work.
GKBO
Me to buffster,soda blasted my 78 GS1000 engine before painting it.Worked real nice,I use washing soda from the laundry aisle at the grocery store.A lot more gritty than baking soda,haven't found a place locally that sells blasting soda.
In other news my waffling on the crank issue has been solved by The Boss.We where up at Kenco and we (she) ordered a new rod kit.Got a set of main bearings at the closest bearing place,much less than getting them though MC specialty places.While we where at Kenco we also picked out all my dirt bike riding gear.As I've been street only till this time I need everything.Had them put it away so The Boss can pay it off.
Speaking of the 1000 I really got to get going on that to.
My other bikes:
My other bikes:
- diymirage
GKBO wrote:While we where at Kenco we also picked out all my dirt bike riding gear.As I've been street only till this time I need everything.
smart man
i didnt buy a chest protector untill after i darn near crushed both my shoulders and misplaced my spleen
i just hope ill be smart enough to buy a pair of riding boots before i loose my pinky toe
did you manage to find a get-up that matches the bike ?
i have this whole set up
http://www.dealernews.com/sites/dealern ... erIon3.jpg
to match my 96 "barney edition" KDX
if there is any money left of the tax return after the wifey gets done with it i would like to get this one aswell
http://mxoutfit.com/cicini/images/detai ... -green.jpg
