Page 4 of 6
Posted: 07:37 am Jun 29 2011
by Fatherof2
Does anyone know if the latest version of the DR helps with these issues? I hear it is made just a bit differently, and is 420 bucks.
Posted: 07:53 am Jun 29 2011
by ss109
Made differently, how?
Posted: 07:55 am Jun 29 2011
by David_L6
sped66 wrote:After speaking with Dave at Revloc, and fully explaining my experience, the only thing left to do is take it apart again & make darn sure the pressure plate is lining up with the inner hub 100% correctly. That & he suggested a sprocket change might help favorably.
(I'm running the stock 13/47 atm. I didn't quite like the tight 13/50 combo I was running before the DR install, but neither do I like the 13/47. Think I'll try 12/47 which might be just a tad lower than the 13/50?)
I'll give it some more time, another test ride or two, & see how it goes. Could be a few weeks before I have anything definitive to report.
I'm running 13/48. If I were going to doing anything different, I'd go back to stock.
Posted: 11:22 am Jun 29 2011
by makeshoes
It sounds like my H model in your video. It is a little hard to tell all the elevation changes in the video though. I do run mine with the stock 3 springs in it. Good luck!
Posted: 09:43 pm Jun 29 2011
by 220ripper
are you running 2 springs or 3?
I tried it with the stock 3 for a few rides and wanted to see what 2 would feel like. . basically the same feel but a quicker engagement point ..
Posted: 10:20 pm Jun 29 2011
by sped66
SS109 wrote:I think I'm going to contact Alan at Revloc and see what he says.
I'd be an eager tester if he has anything to send. I like the product, but apparantly I'm not alone in wishing for something crisper. I'm really on the fence so far. Think I'll contact Revloc as well.
David_L6 wrote:I'm running 13/48. If I were going to doing anything different, I'd go back to stock.
I've definately decided to stay stock. Much less shifting & is close enough for me. Plus, I'd feel like I was putting a band-aid on the wrong scratch if I went back to tighter gearing.
makeshoes wrote:It sounds like my H model in your video. It is a little hard to tell all the elevation changes in the video though.
Mine's an H too. Elevation ranges probably around 100 feet overall at most I think, but does so somewhat quickly in places.
220ripper wrote:are you running 2 springs or 3?
Two.
Posted: 11:36 am Jul 01 2011
by sped66
Nice video!
We dont have any other springs. However, you should find that the springs you have in it at the moment will take a bit of a set and get a little weaker.
Sounds pretty good, defiantly be in the right gear and keep the revs up. Use ATF!
Rgds
Alan
Crud. Well since I have extra springs I'm not using anyway, maybe I'll heat a couple of them up to see if I can weaken them a tad & give that a try.
Posted: 11:50 am Jul 01 2011
by Mr. Wibbens
Now it really is dyna ring hell :wink:
KDX Butterfly wrote:Regretfully, Revloc will soon be moving away from the motorcycle industry. For a limited time, kdxrider.net (along with Revloc) will be offering the Revloc Dyna Ring Auto Clutch for a limited-time price of $329 + $12 S&H.
The 5% discount from Revloc will no longer be available.
If you are interested in purchasing the Dyna Ring at this first-come, first-served offer, watch the top of the screen for a clickable link to Revloc's Dyna Ring.
Posted: 12:58 pm Jul 01 2011
by ss109
Mr. Wibbens wrote:Now it really is dyna ring hell :wink:
No ****! With all the initial problems with it, I'm still trying to get my Dyna to perform the way I want it to, it has less than 4 hours on it, and now the company is bailing on us? :evil:
Posted: 01:00 pm Jul 01 2011
by Mr. Wibbens
sounds pretty sucky
Posted: 01:31 pm Jul 01 2011
by ss109
I should have just saved up for an EFM auto-clutch and been done with it. I think I'll sell it now before parts become a nightmare to get so someone that doesn't ride as much, or as hard, as I do can enjoy it for a long time.
Posted: 01:55 pm Jul 01 2011
by sped66
I'll just keep mine if the "weaker springs" idea works out. I'm too stubborn to throw in the towel just yet. If/when it ever starts falling apart I'll just go back to the stock clutch.
Posted: 03:26 pm Jul 01 2011
by ss109
Please let me know how the springs work out. I might stick with it if they makes a huge difference.
Posted: 04:34 pm Jul 02 2011
by Green Hornet
That sucks. Trail Rider Magazine just gave the Dyna Ring a Nice Wite-Up. Sorry to hear about your problems, I enjoy using my, but it did take a bit to understand & get it adjusted
Posted: 06:57 pm Jul 02 2011
by JoKDX220r
SS109 wrote:I should have just saved up for an EFM auto-clutch and been done with it. I think I'll sell it now before parts become a nightmare to get so someone that doesn't ride as much, or as hard, as I do can enjoy it for a long time.
I moved from an EFM (installed by previous owner) to standard clutch and I really don't regret it !! Just sell your DR and think about another mod :grin:
Posted: 09:24 pm Jul 02 2011
by ss109
JoKDX220r wrote:>|<>QBB<
Thing is, I ride extremely aggressive. I don't just put along unless I'm riding alone. Where I ride there are very tight turns that I need to practically lock up the brakes, turn, and launch out. Sometimes I will hit the rear brake just a bit ahead of grabbing the clutch lever and stall the engine. At minimum that kills my momentum and at worst I drop the bike. Both zap my energy and my flow.
The Dyna Ring fixed that but I want something that will lock up just above idle so that I can keep my speed up better. Are you saying the EFM won't do that? As far as auto clutches go, EFM is the only option left.
Posted: 07:00 am Jul 03 2011
by JoKDX220r
SS109 wrote: Thing is, I ride extremely aggressive. I don't just put along unless I'm riding alone. Where I ride there are very tight turns that I need to practically lock up the brakes, turn, and launch out. Sometimes I will hit the rear brake just a bit ahead of grabbing the clutch lever and stall the engine. At minimum that kills my momentum and at worst I drop the bike. Both zap my energy and my flow.
Then I'm sure you better stay away from the EFM, it can help but you'll have to spend a lot of time tuning it, and it will keep stalling.... You'll also loose your clutch lever..
Posted: 07:18 am Jul 03 2011
by ss109
EFM states that you keep your clutch lever. The tuning I don't mind as long as it will do what I want. Keep stalling? Would you please elaborate on all three points you made? Did you try one on a KDX as you didn't say that is what bike you had it on? Do you just not like auto clutches? More info is needed!
Posted: 03:08 pm Jul 03 2011
by JoKDX220r
Here's a reply from Garry at EFM about the clutch lever : " Sorry no, the KDX clutch works backwards compared to most newer style clutchs "
My bike is a kdx 220 2003, the previous owner was johnkdx220 you can get an idea of the troubles he get throught when he installed it : http://www.kdxrider.net/forums/viewtopi ... hlight=efm
I like autoclutches, I tried some ktms with rekluse on them that worked fine.
Posted: 05:19 pm Jul 03 2011
by Green Hornet
Why are they getting out of the MC Business?
