Virtual, remember, you don't have to buy all those parts from them. You could pick up the clamps and damper anywhere and piece it together with them filling in what you can't find or make yourself.
I had the 2002 KX250 with that set of T-clamps I bought off eBay for about $50 if I recall. They are out there although that was 4 years ago.
Hmmmm.... Maybe I'll do a little looking around. I've got another 2002 KX250 so maybe I could set it up....
****EDIT****
Well....
Lookie here;
http://cgi.ebay.com/ebaymotors/BRP-SOLI ... ccessories
****EDIT AGAIN****
A second set!
http://cgi.ebay.com/ebaymotors/BRP-RUBB ... ccessories
And these ones have the rubber cones you speak of.
Scott's Stabilizer with KX Fork Conversion
- Varmint
HA!!!! The identical picture! My "blow out hard to pass up price" was $80.skipro3 wrote: ****EDIT****
Well....
Lookie here;
---edit---
My call today must have prompted him to clean out the stock room!
Re: 'the free return to center (dirt)...'
..and
Re: 'And the Scotts guy told me that damping in both directions is good for dirt.'
So...based on what folks have been told, the Scotts doesn't damp at all?
Is that right?
Whut...you're gonna believe the last thing you heard...or what the fact of the matter is.
Inda...you have a DIRT damper? ..and it does, or does NOT damp TO center?
It's nice that your cross bar clears the Scotts...but I suppose that's 'cuz you have them fairly far forward?
One size clearly does not fit all. It would be nice to have some clue what the sizes WERE to start with! (having nothing to do with SIZES..it's a METAPHOR 'fer crine out loud!!)
Unless..I said, 'Like...one size clearly does not fit all...'
..in which case it would be a SIMILE.
Keep up!!
Not to queer the as of this point the clearly understood (everbuddy but me) facts of the matter...but...
Re: '..he suggested rubber mounts.'
Meaning..the BRP clamps have tapered holes you can put bushings IN? I don't see that from your pic. Not sayin' they aren't there..just that I don't see 'em.
'Suggesting' iso mounts isn't an option. Your triples either take iso mounts...or they don't.
I have an Applied clamp (from ski) for phat bars (I think). I haven't pursued that idea 'cuz my 7/8" work just fine...and they ARE iso (I like that) and the Applied is NOT iso.
But (yet another one)..7/8" or phat isn't really the choice, seems to me. It's, 'You want to (can you) have a cross bar fit 'yer stuff...or not?'
Re: 'nor would you I imagine..'
Sounds reasonable.
I do know that the repeated reference to fork flex on the OEM RSU forks isn't anything I appreciated...until I put the USDs on. THEN the WER 'all-of-a-sudden' had SOME impact on defletions.
Prior to the fork swap? ...I had NO clue it was even there. Not because it worked so seamlessly that I didn't notice...but 'cuz it didn't do squat.
Now, at least...it DOES!
..do squat.
..and
Is that right?
Keep up!!
Sounds reasonable.
..do squat.
Geesh.... It is what it is... don't know how I would check that unless I called Scotts! Seems some folks already did that.
These things ARE Rocket Science and cannot be checked for return to center dampened or undampened by turning the handlebars real fast. Just a fact!
BUT.... I do seem to remember that was one of the main differences between a Scotts and a WER..... A Scotts dampens both ways and a WER only one.
- skipro3
