Page 3 of 4
Posted: 09:15 pm Aug 01 2006
by awoodman
okay...thanks...and im going to get the pipe and silencer soon hopefully and i hope everythings a good fit...is the powercore2 better than the turbinecore 2?
Posted: 09:19 pm Aug 01 2006
by Indawoods
Get the TCII... or you might find yourself unable to ride in some places. Also... it's the responsible thing to do...
Posted: 09:21 pm Aug 01 2006
by awoodman
well what im after is more power...
Posted: 09:24 pm Aug 01 2006
by Indawoods
You won't notice a bit of difference...
Posted: 09:26 pm Aug 01 2006
by awoodman
okay, thank again! and where is the cheapest place to get the pipe, silencer, and jets?
Posted: 09:29 pm Aug 01 2006
by Indawoods
Shop around....
http://rockymountainatv.com or
http://monkeybuttparts.com usually has good prices on pipes and such... Jets you will have to get from a dealer or
http://sudco.com
Posted: 09:34 pm Aug 01 2006
by Ryan
i was able to hear both the turbine core II(i own it) and my cousins power core II. As far as noise the powercore was a good bit louder. So i repacked it and now it is very quite, still a tad louder than the turbine core II but not much. As far as power difference none was noticed.
Posted: 09:42 pm Aug 01 2006
by awoodman
alright, thanks a lot guys...
Posted: 06:00 pm Aug 02 2006
by awoodman
and has anyone ordered from monkeybuttparts.com? is it reliable and good and all that?
Posted: 06:11 pm Aug 02 2006
by Indawoods
Yep.... great service!
Posted: 08:13 pm Aug 02 2006
by awoodman
awesome. did i hear that it is necessary to breaka pipe in or something? if so, how do i?
Posted: 07:54 am Aug 03 2006
by krazyinski
awoodman wrote:awesome. did i hear that it is necessary to breaka pipe in or something? if so, how do i?
after you bolt the pipe on you have to go out and ride the snot out of it. if not it just wont work as good in the driveway, also while riding you cant hear your wife nagging at you about spending so much on the bike.
Posted: 08:45 am Aug 03 2006
by awoodman
haha, good...so I just ride it like I normally would? just rev it a lot? no problem...thanks
Posted: 05:11 pm Aug 15 2006
by awoodman
so if im running a 32:1 mixture and at 300 ft. elevation, and have a FMF Gnarly Desert and PowerCore2 silenver, I should put in 155 main and 45 pilot jets? And what should the little air screw be set at, and can you tel me what it means? Like when you say 1/2 turn, does that me screw it all the way in, then out 1/2 a turn? Sorry, new to fine tuning. I wont be doing the reeds right now, but I did order the pipe, silencer, and the jets you told me, so I hope it all works out! They are on they way from FRPOFFROAD. Thanks again guys!
Posted: 05:55 pm Aug 15 2006
by strider80
155MJ and 45PJ is a good place to start anyways, it will probably be a bit rich still.
Yea, all the way in on the air screw and then about 1.5 turns out, tune it in from there. Screwing it out makes it leaner, in makes it richer, only affects 0-1/4 throttle though.
Posted: 06:49 pm Aug 15 2006
by Green Hornet
I like my 12/47 combo on the 220. I find my self running 3-4 gear in crap I would have been riding 2-3 gear in. Also, I can leave the bike in 3rd, fan the clutch in single track & continue boucing off trees with the up most speed
Posted: 07:23 pm Aug 15 2006
by awoodman
Green Hornet wrote:I like my 12/47 combo on the 220. I find my self running 3-4 gear in crap I would have been riding 2-3 gear in. Also, I can leave the bike in 3rd, fan the clutch in single track & continue boucing off trees with the up most speed
I plan to screw with my gearing sometime after I get the engine tuned in, so ill look back at this thread, at what you said while im changing sprockets. Thanks for the help!
And, strider80, how exactly do i tell if its too lean or rich? Do I just back it out until the bogging has stopped and the engine is running smoother? Id hate to go too lean and damage the engine.
Posted: 10:43 am Aug 16 2006
by strider80
Start at 1.5 turns, let the bike warm up then screw in the air screw till it wants to die then screw it out till it idles good then screw it out some more till it runs rough then put the screw somewhere in between. Once you get it close you can fine tune it for crisp throttle response.
The air screw only affects the mixture from 0-1/4 thottle, so not too much risk of damage, not very much heat being generated at low revs.
by strider80
awoodman wrote:and has anyone ordered from monkeybuttparts.com? is it reliable and good and all that?
I have ordered 3 times from monkey in the last month, everything has been great.
Posted: 07:06 pm Aug 16 2006
by awoodman
okay, thanks, i got the pipe and silencer and jets from frpoffroad instead
