I am contemplating shaving a small amount off of the bottom of the carb to emulate buying a leaner slide, I'll have to take it apart and have a good look first though!
Posted: 11:17 am May 15 2011
by kdxmaniac
a video of the bike running would be good!
Posted: 01:51 pm May 15 2011
by moto_psycho
In the words of a complete twat, "I shall try my utmost"
Posted: 03:24 pm May 16 2011
by moto_psycho
Definitely needs a larger pilot jet, will get a few on order 2moro
Posted: 09:23 pm May 16 2011
by David_L6
moto_psycho wrote:Definitely needs a larger pilot jet, will get a few on order 2moro
That doesn't surprise me. Weaker signal....
I have fooled with carbs a LOT on boat motors. Not so much on motorcycles, but theory is the same.
From experience - 44 cubic inch 4 cylinder outboard with 2 carbs:
Motors come with two 1" carbs. Mercury made several other sizes of carb for different motors - 1 1/16", 1 1/8", 1 3/16", 1 1/14".... The motors were designed to turn ~ 5500 RPMs stock. We turn them ~ 8500 RPMs on our hydros. We can't do ANYTHING to increase compression ratio. We can port them all we want to (in fact, we can remove all the metal we want to - just can't add any). The 1 1/4" carbs are way too big for anything. The 1 3/16" carbs are way too big for racing. The 1 1/8" carbs run good down the straights on a 1 mile course, but they give up too much coming out of the turns and they are too big for 3/4 mile. The 1 1/16" carbs worked out to be the best 1 mile courses. The stock 1" carbs are tough to beat or courses shorter than 1 mile. I run 1 1/16" carbs everywhere. Some of my competitors switch between 1" and 1 1/16" carbs depending on the course. The smaller carbs work better on the shorter courses. Why? The motors spend more time accelerating on the shorter courses. Even though I can run a Holley 4 barrel, it wouldn't do me any good. The motor can only use so much carb.
Posted: 12:09 am May 17 2011
by moto_psycho
It is definitely a jetting issue at the moment though, it doesn't feel like too much carb atall (I've over carbed before!) this is literally a case off to small an idle jet, the bike is hunting at idle and I have a smaller jet installed than recommended for the carb.
But as you say, weaker signal, but with the carb being so much closer to the action I definitely believe it is made up for, as the second the needle comes into play (just over 1/4 throttle) the bike takes off like... a powerboat
Posted: 02:36 pm May 19 2011
by moto_psycho
Interesting, when I snapped the throttle shut the needle got jammed in the main jet had to make a shim up for it.
Also, fitted 50 pilot jet, has cleaned up the bottom end, but I really think I need to get a leaner slide so I have more adjustment on the needle. Then from that I need to get a needle that is slightly richer at 1/4 throttle.
The bike feels nigh on perfect atm, but there is always more to be had
Posted: 01:47 pm May 20 2011
by moto_psycho
Video;
Needs a larger main jet atm, I went down 5 sizes on pilot and it affected WOT rather severely, so its not revving out as much as it had done before hand, but there you have a video of it running :)
45 Pilot
CEL Needle top clip
180 Main (changing to 190 2moro)
[youtube][/youtube]
Posted: 08:37 pm May 20 2011
by TWMOODY
Sounds like a turd bike to me
Did you give it more than half throttle on your
way down that hill ?
Posted: 09:14 pm May 20 2011
by SS109
Not worth my time.
Posted: 04:04 am May 21 2011
by moto_psycho
perhaps the main jet being on the leaner side of correct?
bit of math for you
pilot 50
main 180
WOT - 230
pilot 45
main 180
WOT - 225
Posted: 07:51 am May 21 2011
by Tedh98
Don't forget to post the before and after dynos
Good work on that adapter though.
Posted: 11:36 am May 21 2011
by SS109
Not worth my time.
Posted: 12:21 pm May 21 2011
by moto_psycho
Do me a favour and get me a schematic of the valve that shuts off the idle jet at anything over 1/4 throttle then please mate...
And no, my idle is perfect, if you really want I could use a timing light to find exactly how many hundred rev's it is idling at. Air screw is 1.5 turns out which is directly in the middle of the adjustment range, it is perfect.
Also, the idle circuit on this carb bypasses the slide completely, at idle the slide is 100% shut.
Pilot jet 45
Needle CEL top clip
Main jet 190
best setting so far :D, gonna try 200 main 2moro, though I doubt it will improve, but I'll never find out if I don't try!
Quote from a well known jetting guide;
"It's very important that you start with the pilot circuit. The reason is simple. The pilot circuit affects the entire throttle range. When you are at full throttle, the main jet is the primary fuel metering device, but the pilot is still delivering fuel as well, adding to the total amount of fuel that your engine is receiving."
Hah! How am I not worth your time? You've learned something quite important about jetting from me, what have I learned from you?
I find it quite funny, before I fitted the carb half of the forum was swarming on this thread, itching to read of my absolute failure, now it works far better than expected, everyone buggers off.
Posted: 03:02 am May 22 2011
by moto_psycho
Also, I will next try shimming the needle to see if that provides any better performance, and should give me a ballpark figure on what slide I need to buy!
Posted: 03:17 am May 22 2011
by moto_psycho
TWMOODY wrote:Sounds like a turd bike to me
Like I said, top end was upset at that point.
Posted: 08:32 am May 22 2011
by kdxmaniac
moto_psycho wrote:Hah! How am I not worth your time? You've learned something quite important about jetting from me, what have I learned from you?
i havent learned anything from you.....you put a carb on your bike and made it run{somewhat}......but, did you not take a carb off your bike that was running?
i just dont see why you want to go thru the trouble to install that carb, when you could have jetted the stock carb.
but, i guess if your THAT bored, go for it.
Posted: 09:02 am May 22 2011
by Julien D
As far as I can see, it's working about as I expected.
