A few questions about my 94 kdx200
david
Country: UNITED STATES
Post by david »
125-135 range. I know that's not exact, I glanced at it last night in the manual but can't remember the exact numbers
Edit: I just looked, book says 119-185 usable range
'81 KDX 175
'90 KDX 200
'82 Honda GL500 (sold)
'96 ZXi 1100 JetSki
'98 STX 1100 JetSki
ubareddition
Re: A few questions about my 94 kdx200
Post by ubareddition »
Here some pictures from yesterday. Before the disaster.
Sent from my SM-N910V using Tapatalk
david
Post by david »
First big rock or log you go over is going to rip that bicycle kick stand right off and probably dump you on your ear too. If you decide to continue, replace it with the correct one. The H series will fit too.
'81 KDX 175
'90 KDX 200
'96 ZXi 1100 JetSki
'98 STX 1100 JetSki
Friedom
Post by Friedom »
Are your head bolts loose?
"Good job, guys. "
Friedom
Post by Friedom »
And what kind of 2t oil, gas and ratio did you run?
"Good job, guys. "
ubareddition
Head bolts are not loose just checked. This is the oil I use.
40 to 1.
Take the pipe off and look inside.
Dekon
Post by Dekon »
Never give up, you've come to far to quit now. Just a suggestion, did you tighten the nut on the water pump shaft? Maybe you over heated it.
ubareddition
Yes I tightened the bolt on the water pump shaft.
I just made a kind of leak down tester from parts I had laying around. Image
Took the shredder valve out of my compression tester.
Image even at 20 psi I can still hear hissing out of the pipe and air box.
ubareddition
Regardless where piston is. But I made sure it was at tdc before starting the test
You can't do a leak down or vacuum test with the exhaust exit and intake not plugged.
And one only pumps it up to about 7 psi. 20 is for popping seals.
ubareddition
How would I go about properly plugging the intake and exhaust?
ubareddition
Oh I just saw something thru the intake port I didn't want to see
Breathe and reply back
ubareddition
So this is what I saw thru the intake port Image
So I took the jug off and this is what I saw. Image
ubareddition
The inside of the cylinder looks fine to me a little scratched but not as bad as the piston. It looks to me that the cylinder scratched the hell out of the piston. Not the other way around.
ubareddition
Here's some pics of the cylinder to show you guys. Tell me what you think. Image
Here's a close up of the gouges on the piston
4 corner seizure?
ubareddition
I'm not sure what that is
