It begins! '90 KDX200 rebuild
Has thanked: 30 times
Been thanked: 47 times
david wrote:The 'damage' on the spare is nothing. Dress it with a file and run it.
That is what I decided to do. Now the output shaft is back together and all is assembled back into the right case half. Just waiting on my one single bolt to arrive.
Still waiting on my bolt to get here. It finally shipped but won't be here until next Tuesday. Yeah. :roll: In other news, my frame is out getting sandblasted, I ordered that ignition system from the guy in Ecuador, and the radiators should be here any day now. Also tried to remove some skin off my thumb today while prepping other parts. I wonder how a glove will feel on it when I ride this weekend?
go get something called liquid band aid (walyworld...)
This will heal a LOT quicker, AND that stuff is like superglue, makes a nice waterproof (dry) coating on it. That way your glove ain't gonna stick to your skin :wink:
Bright red blood is just a scratch. Dark red blood that runs down to your elbow is when you got it good. Just set down your purse and hike up your skirt, then go riding! :lol:
scheckaet wrote:go get something called liquid band aid (walyworld...)
I tried that stuff once and it burned like hell. No thanks! :shock:
rbates9 wrote:Bright red blood is just a scratch. Dark red blood that runs down to your elbow is when you got it good. Just set down your purse and hike up your skirt, then go riding! :lol:
But, but, my panties are in a bunch! :mrgreen: I'm not too worried about it. Just don't want blood all over the inside of my glove.
:mrgreen:
wuss...
scheckaet wrote:wuss...
Yup! :mrgreen:
KDX200-E2
Post by KDX200-E2 »
Daaaaaammmmmm You guys a rough. Give a guy a break. Im sure that hurt like hell.
(note to self) next time I get a splinter under my thumb nail.... don't come here
looking for sympathy.
Heal fast and finish that bike.. You can ride later.
Cheers, Jeff
david
Country: UNITED STATES
Post by david »
When you've been through the stuff some of us have, it takes a dismemberment to get some sympathy. Or at least, a broken bone.
'81 KDX 175
'90 KDX 200
'82 Honda GL500 (sold)
'96 ZXi 1100 JetSki
'98 STX 1100 JetSki
Damn, I cut of my leg today but a little liquid band aid and duct tape and now I'm all good. :mrgreen:
On a serious note, I got my frame back today. It was so worth the $40 to have someone else do it! :supz:
Has thanked: 160 times
Been thanked: 40 times
Is that painted white or sandblasted??
Been thanked: 17 times
That looks bead blasted to me. Really nice finish you get with that stuff!
It is raw, blasted steel. I plan to get it in primer tomorrow. Here is the best pic kind of showing the finish after blasting. You can see where the VIN is what it looked like where I stripped it and how it differs from the blasted area.
Guys, my crank appears to be off to the right side of the case. There is almost no gap on the right and probably a 1/16 or 3/32 gap on the left. The case bolts are all seated and torqued so is this normal or do I need to do something to correct it? Also, I made my own crank installer using old trans gears and the primary gear nut. It worked pretty good but got hard to hold the crank from turning. I used it down to where I could get the case bolts in at least 4-5 full turns and then used them to finish pulling it together.
crank spacing.jpg (208.94 KiB) Viewed 9037 times
You can not use the case bolts to finish it off. You need to fully seat the crank with the puller until both case halves are fully seated, then you can install them. Pull it back apart and use a proper puller.
Frysk
Post by Frysk »
when I've installed a crank I just used a plastic hammer and hit it till its in the center of the case.
I used a feeler gauge to see if its lined up right, no fancy tools just a swing of a hammer :)
Has thanked: 10 times
Frysk wrote:when I've installed a crank I just used a plastic hammer and hit it till its in the center of the case.
This. I use a block of wood and a mallet. It's not very hard to center it up.
Hammering the crank don't you run the risk of taking it out of true?
Re: It begins! '90 KDX200 rebuild
Slick_Nick wrote:Hammering the crank don't you run the risk of taking it out of true?
Sure, if you go whaling on it I guess you could. Never had it happen. I stick a box end wrench that just barely fits in between the crank halves. I've also seen people use plastic shims. I've done it this way many times and never had a problem. Is it the best way? Probably not. It definitely works though, and I've seen mechanics way better than I will ever be do it the same way.
