Page 11 of 22
Re: A few questions about my 94 kdx200
Posted: 11:38 am Sep 29 2016
by Friedom
That doesn't look like a stock silencer.
"Good job, guys. "
Posted: 11:39 am Sep 29 2016
by ubareddition
It says it is on the outside casing. I can take a picture of it later.
Sent from my SM-N910V using Tapatalk
Posted: 11:51 am Sep 29 2016
by Friedom
Well one of us doesn't have stock, cause mine says it on the casing too but it doesn't have that fancy blade thingie in it. I think that's a FMF turbine core II.
It's a good thing if it is :)
"Good job, guys. "
Posted: 12:00 pm Sep 29 2016
by ubareddition
Hmm the bike did have a fmf sticker on it. I just figured it was for the gold series woods pipe.
Posted: 02:59 pm Sep 29 2016
DO NOT let the EZ Off soak for long on aluminum. A few minutes and rinse
Posted: 07:23 am Sep 30 2016
by ubareddition
My new case came in. Looks good. Didn't have any time to do anything before or after night school. But tonight we will see how much I can get together.
Posted: 11:12 am Sep 30 2016
by ubareddition
Does anyone know what the proper break in procedure is for a new rebuild?
Posted: 09:30 pm Sep 30 2016
by Friedom
ubareddition wrote:Does anyone know what the proper break in procedure is for a new rebuild?
There are many trains of thought here. Mine was simple: warm it up and ride it. The rings will seat and it'll be great.
Check the torque on your head bolts after the first couple rides though.
Read around. Some people say hat cycles and baby it in, some say you only get that first time to really set it for running under load. They both seem to work.
"Good job, guys. "
Posted: 03:06 pm Oct 01 2016
by ubareddition
Posted: 12:11 am Oct 02 2016
by ubareddition
Any tips on stripped Allen head bolts for the rear brake. The slider pins that hold the pads in place? I don't wanna spoil anything but that's the only thing holding me up right now.
Posted: 12:44 am Oct 02 2016
by Friedom
Cut a slot with a Dremel and use a flathead to get them out. Then you can replace them or use again.
"Good job, guys. "
Posted: 08:16 am Oct 02 2016
by ubareddition
Cut a slot even though they are flush with the caliper surface?
Posted: 08:31 am Oct 02 2016
by Friedom
If you're able to do it without damaging the caliper, yes. Small cutting wheel usually does the trick. There are other methods, but this has worked well for me.
"Good job, guys. "
Posted: 08:47 am Oct 02 2016
by ubareddition
I'll get some smaller cutting disks.
Posted: 08:57 am Oct 02 2016
by Friedom
Alternately you can weld a Allen key into place, but that's a bit harder to clean up and make useful afterwards.
"Good job, guys. "
Posted: 09:00 am Oct 02 2016
by ubareddition
So here's what got done last night till 330 am when I couldn't do it anymore.
Cleaned the new inner clutch cover. Took all the old seals and bearings out. Then took all the new seals and bearings out of the case I cracked. Transfered them over. Installed the cover.
installed the outer clutch cover with new seals.
Installed new wrist pin bearing.
To be continued
Posted: 09:09 am Oct 02 2016
by ubareddition
Friedom wrote:Alternately you can weld a Allen key into place, but that's a bit harder to clean up and make useful afterwards.
"Good job, guys. "
Tried that already. Didn't work. Very hard to weld a good bead all the way around. It's a very small area that's exposed.
Posted: 09:10 am Oct 02 2016
by Friedom
ubareddition wrote:Friedom wrote:Alternately you can weld a Allen key into place, but that's a bit harder to clean up and make useful afterwards.
"Good job, guys. "
True. I've never had any luck doing it either, but the heat you applied should help break it loose.
"Good job, guys. "
Posted: 09:24 am Oct 02 2016
by ubareddition
I'm going to go to home Depot later to get small metal cutting disks for the dremel.
Posted: 09:26 am Oct 02 2016
by Friedom
Do you have one of those impact tools that will turn something a small but powerful appoint when you hammer it? I've had great success getting things loose with one.
"Good job, guys. "
