Page 2 of 2
Posted: 07:07 pm Dec 15 2010
by Mr. Wibbens
I run Engine Ice in both my bikes, just because someone gave me some
But eventually the kdx ends up just running straight water, from having to refill it though out the course of a ride
Posted: 03:02 am Dec 16 2010
by Budget_89KDX
I like and run the redline stuff called water wetter.never used the purple ice stuff.but the water wetter works and really good stuff especially for those of you in the warm climates year round that want to run water it has additives for anticorrosion and the lube things like water pumps need.
I know a lot of circle track guys that use it and recommend it with straight water for best results since it lowers the Watt surface tension.can't comment on that though I run it in with my 50/50.
Posted: 03:07 am Dec 16 2010
by Budget_89KDX
>|QBB|QBB|QBB<[/url]
Fortunatly, 2 strokes are nearly impossible to overheat (KTM 300 being an exception). That's why so many people use them in the Erzberg and other extreme enduros.
Most clouds of steam have a 4 stroke under them.
[/quote]
then what's up with my bike? I've got Devol rad guards, and everything else is stock. When riding slowly on techy uphills she likes to overheat. I've bled the air out of the coolant when I changed the coolant to a 50/50 premix from the stock coolant that's been in there for 5 years.
it's to the point that I carry a small bottle of top up coolant on the more difficult rides.
Any suggestions? The radiators are not dented and no tubes appear pinched. I've drained the coolant and didn't find any blockages.
Engine is stock 2005 KDX220 (yeah, I know - change the piston)
[/quote]
Have your cap tested.any autoparts store should have a tester for sale or rent.autozone had one to fit my buddy's raptor.it came in a big kit to pressure test the coolant system as well as the caps.couldn't tell you a price though.
Posted: 10:16 am Dec 16 2010
by fuzzy
220's seem to do this more.
Search on here as it was covered a lot years back. I believe the solution was a different rad cap w/ slightly higher pressure.
Posted: 01:56 pm Dec 16 2010
by Mr. Wibbens
I run a 16# cap on my 200
It has helped a lot but I still boil over when I lug the piss out of it
Posted: 09:54 am Dec 17 2010
by fuzzy
I wonder if you could run some computer fans off the coil
Posted: 03:17 pm Dec 20 2010
by heckler
new OEM radcap is on order.
and my Wiseco piston/bearing/wristpin! Prepare yourselves for the first timer top end rebuild questions....
Posted: 04:55 pm Dec 20 2010
by Mr. Wibbens
heckler wrote:new OEM radcap is on order.
Hope you don't have to pay an OEM price for it
Could have just taken your cap down to an auto parts store and matched up a new one
