I'm pretty sure I used Moose gaskets, this top end and the last
Never noticed any issues
Posted: 10:27 pm Dec 03 2010
by Mr. Wibbens
e 10 runs fine in my KDX, but I usually add toluene to my mix
by kdxmaniac
Mr. Wibbens wrote:I'm pretty sure I used Moose gaskets, this top end and the last
im not saying you will have problems.........I just have to make sure the bikes i build last.........and moose makes 2 diff gaskets. if the compression is 210, anything over 210.......your pushing your luck, and i dont have very good luck!! like i said, you may get by. alot of it has to do with the bikes jetting, and elevation, and temp, humidity, and how you ride.......
Posted: 10:30 pm Dec 03 2010
by kdxmaniac
Mr. Wibbens wrote:e 10 runs fine in my KDX, but I usually add toluene to my mix
put a gauge on it and see what she blows............bet its around 165psi-175psi....see if im right.
Posted: 10:48 pm Dec 03 2010
by Julien D
Usable range for the E series is 119 to 185. Anything higher or lower can't be assumed to run well on the recommended fuels.
If it rips, and it sounds good, I wouldn't worry much about the compression reading. If you don't get any detonation running 87, then it should be fine to run that. Not quite adding up in my mind with 210psi, but hey. Stranger things have happened.
Are you checking it cold, or hot?
Posted: 10:55 pm Dec 03 2010
by kdxmaniac
if he used the high compression gasket, it is thinner, therfore loweing the cylinder, therfore the piston is closer to the head, making the actual cc's on the head less.............in return making more compression......
add up now?
i dont think anyone should run 87 on a engine making 175psi or higher.....just my 2 cents..
also........119psi would be a dog.
Posted: 12:22 am Dec 04 2010
by Budget_89KDX
Its for sure moose's high compression top end kit and yea the head and base gaskets were thin.
I'm checking the compression cold.its too late by the time I get off to fire it up I have a 17 month old daughter and the old lady would bitch.I just hooked up the gauge held the kill switch throttle wide open and gave like 5 kicks and it didn't spike any higher than 210psi.I had 195psi before the moose kit 15psi don't sound like much of a bump in compression to me.
As for the fuel I don't know where you live bro but I've yet to see a station in these parts that don't say 10% ethanol.the bike was tearing it up on the old railroad access road up the way from the house when I took it out and besides the exhaust note changing from the new pipe it sounded awesome.
I'm going to pissed if I just built a grenade!
Posted: 12:38 am Dec 04 2010
by Mr. Wibbens
You can buy non e10 around here, I just don't see the point, I have not noticed any difference running it in any of my equipment
Posted: 02:40 am Dec 04 2010
by Budget_89KDX
Where's around here?
Posted: 07:23 am Dec 04 2010
by Mr. Wibbens
Posted: 08:40 am Dec 04 2010
by kdxmaniac
you didnt build a grenade...........you just build a strong running motor that youll be happy with! i live in s.c........out in the country, and theres 2 stores right up the road, that sell non ethonol. hell, just ride it............you can run water if thats what will run in yalls bike..........dont bother me. im just telling my experiance on the matter. this is the facts, now YOU dicide.....
ethonol"alcohol" burns colder........but leaner!
it take 10%-20% MORE alcohol than gas to make the same power!
alcohol draws moisture, so dont leave it in you bike for a long time!
210psi or more........ I WOULD NOT run 87..........but, do you feel lucky?
all my bikes have over 220psi...{besides kdx}.......runs like a raped ape!
its all in the fuel and the setup...........i have 12.1 compression in my mustang drag car, and running 6 psi boost on that, with a 90 shot"only when needed "...........motor has held up for 3 years now....but......i run straight 114 , and make one run and the temp spikes to 210 degrees.
Posted: 08:28 pm Dec 04 2010
by Budget_89KDX
>|QBB<[/url]
Mr. Wibbens wrote:
Well I'm in illinois bro and all we have are confields and I've kept my eye out for non ethanol and race gas and have yet to see either.like I said I know a place a couple towns over had a pump with turbo blue race fuel but to my knowledge they've closed.hey indo you run race gas?if so where do you buy it?
Posted: 08:30 pm Dec 04 2010
by Indawoods
I just run premium. There are station that have non-ethonol gas but not worth chaising down.
Posted: 08:40 pm Dec 04 2010
by Budget_89KDX
kdxmaniac wrote:you didnt build a grenade...........you just build a strong running motor that youll be happy with! i live in s.c........out in the country, and theres 2 stores right up the road, that sell non ethonol. hell, just ride it............you can run water if thats what will run in yalls bike..........dont bother me. im just telling my experiance on the matter. this is the facts, now YOU dicide.....
I appreciate the advice this is my first kdx so I'm always open to suggestions and experience others have and think ill stear clear of 87 and use the 89.
Now I do call bull **** on a sbf under boost running (atleast for very long) of any kind running a 12:1 c/r.bro I've raced every year for over 10yrs and am ford certified and was a tech for years before and after the military and mustangs mostly have been my choice to build off of and have owned 27 different 79-93 fox bodies with countless engine combos and have yet to see one go that high with 6lbs and spray not spit the head gaskets constantly even o-ringed.what type of huffer you using and at those c/r's how often you putting head gaskets in it?also what type of heads you using?I run 1/8 what do you drag?
Posted: 08:46 pm Dec 04 2010
by Mr. Wibbens
Indawoods wrote:I just run premium. There are station that have non-ethonol gas but not worth chaising down.
Carvr runs non e
smells putrid too me?
I'm always asking him if he's running old gas
Posted: 08:47 pm Dec 04 2010
by Budget_89KDX
You guys still got turbo blue over there?what are your suggestions for fujel in contrast to compression readings for these kdx's?how high is your kdx reading?
Posted: 08:59 pm Dec 04 2010
by kdxmaniac
its a 347, afr 205 58cc blower ported, cometic mls head gaskets, 11.1 pistons, block decked.......real compression is 11.4:1..........and a 50-90 dry shot, when needed>..........wont give you any more info on the motor tho......owned the car for 10 years now, i will tell you that.
this is my OLD stock bottom end motor {stock} in a bone stock gt, bone stock suspension daily driver.......not to bad.
my buddies stock suspension class mustang
my boss mans car
mine is faster, but he is on motor!
my buddies car{scamp} on drag radials.
Posted: 09:02 pm Dec 04 2010
by Indawoods
If it isn't pinging... don't worry about it. You would hear it....
Posted: 09:12 pm Dec 04 2010
by kdxmaniac
whats you times? and mph?
Posted: 09:23 pm Dec 04 2010
by Mr. Wibbens
Indawoods wrote:If it isn't pinging... don't worry about it. You would hear it....
