What I meant to say is this:
It moves the stack away from the valve or moves it closer depending on how you adjust it. This in turn adjusts you stack... er kinda. I know how it works but kinda hard to put into words.... proly why they didn't!
And...Eric Gorr wrote: All Japanese dirt bikes have suspension adjusting screws that affect the low-speed circuits only.
...both from his 'Video Suspension Tuning' write-up.Eric Gorr wrote:
The external adjusters, low speed compression and rebound....
Low, mid or high is not determined by how far the fork tube or shock shaft travels. Those terms only relate to tube/shaft speed.-LSC= low velocity (slow speeds - small bumps - shorter shaft travel)
-MSC= mid velocity (medium speed - medium bumps - medium shaft travel)
-HSC= high velocity (high speeds - large bumps - longer shaft travel)
.. is certainly true. Depends on the level of discussion you're having...or the level of the people you're discussing something with. The new reader would read the above quote reference and certainly think bike speed had something to do with it.Jason wrote: '..the LSC, MSC, HSC comment section you posted could lead one believe it is partly due to the speed of the vehicle...
