2002 Hybrid Build
bulabula09
- frankenschwinn
- frankenschwinn
Sun I pulled the motor and completed the final fab work. All Pieces are in place and temp paint is done.
I cut the frame loops from the KDX and welded them to the KX frame:
I had made a Skidplate for the KDX and it ifit perfectly. The one thing I hate about the skidplate was the hassle of getting it mounted. So I made plates with nuts welded to them and welded those to the frame to eliminate the loose skidplate mounting brackets:
I had bought some new footpegs that were a little bigger (the original ones were bent anyway) and found that I had to pull the motor to get the clutch side mounted. So I took the oportunity to install them while the motor was out. Also, riding trails without a kickstand really sucks so I bought a Trail tech for a 2003 KX125 (they don't make one for an 02) and modded it to fit::
While working on all of this I found that my kick starter was cracked. I have a KX250 kicker on the way but I welded this one for the time being:
Should I put the KX125 kicker on the 250 knuckle or just leave the 250 kicker?
All that is left is the 2002 WR250 petcock to resolve this clearance issue:
PJ1 does not make the Kawasaki green anymore so I bought some grabber green for the areas I welded and ground on. I will tear down this winter when the snow comes and have it powder coated silver or black.
- scheckaet
"found that I had to pull the motor to get the clutch side mounted"
I have the same issue.
I'm interested about that WR petcock, what's the deal with it? shorter? Does it have a reserve setting unlike the stock kx?
I went around the petcock clearance by molding it in using the heat gun, work good so far.
Would you get a pic of the chain guide? Do you have a rubber part in it or does the chain rub on the metal?
Sold ☹ DRZ 400 SM
Sold ☹ DRZ 400 SM
- frankenschwinn
>|QBB<[/url]
You can see that the outlet points to the rear horizontally rather than down vertically and it does have a reserve. I should have it today or Mon.
On the chain guide. The stocker has a rubber block insert but mine was worn through. I replaced it with a primary drive unit. It was just a few $$$ more than the ruber insert for the stocker and I wanted black
Stocker I have already discarded the ruber part:
Primary drive chain guide:
This is the ruber insert:
http://www.rockymountainatvmc.com/produ ... Parts=true
This is the primary drive chain guide:
http://www.rockymountainatvmc.com/produ ... lyId=24705
I had to use the stock spacers for the top block
Here is a pic of the WR petcock:scheckaet wrote:"found that I had to pull the motor to get the clutch side mounted"
- frankenschwinn
- scheckaet
I want that same petcock, where did you get it? ebay?
That primary drive chain guide looks good, gonna have to order one myself, the stock is junk, can't even put a rubbing block on the bottom part
Sold ☹ DRZ 400 SM
Sold ☹ DRZ 400 SM
- frankenschwinn
I had a guy I know in Austin order it for me. I am sure you could get it from bike bandit or something though. Or I can ask him to order another. You will have to pick it up at Cross Timbers or Stillwater 500 when I host the first annual Oklahoma Hybrid Rally.scheckaet wrote:I want that same petcock, where did you get it? ebay?
hockeyboysomers
I used a new 1999 KX250 kickstart lever. I used it full size. It's lighter, stronger and longer than stock. It might not work for someone on the short side, I don't know. I had to use a washer under the nut to take up some slack. I prefer it to the stock lever. I've also heard that if you use the shorty lever, you hit your foot on the footpeg. Good luck!
- frankenschwinn
HRDROKN
Not sure what franken.... did, but this is what I found.500 HORS wrote:Please confirm, but it looks like you used the KX throttle cable and the KDX Keihin carb - is that correct?
thx.
I ordered a motion pro throttle cable for a 99 KX125 and it was exactly like my 03 KDX cable and fit perfectly with the KX throttle. Ordered it from
motosport.com for $17.
HRDROKN
00' KTM 300exc (sold)
99'/03' KXD Hybrid, ****'s Racing Susp, RB carb / head mod.
- frankenschwinn
