Alright... which Octane Gas and what Premix?
- scheckaet
don't think it's an octane issue more likely a jetting issue...
Sold ☹ DRZ 400 SM
Sold ☹ DRZ 400 SM
- Mr. Wibbens
Run whatever makes you happy
I've tried regular, bike ran like ****
I'll stick with super
- KDX4ID
CURRENT FLEET
2008 KTM 990 Adventure...Alaska here I come!
2010 KTM 300 XCW... stop me before I buy again!
2005 KDX220... single track sweetie
2007 KTM 450 EXC... my baby
2008 KTM Superduke... Canyon Carver
1996 Honda 650L... GONE but not forgotten
http://www.friendsoftruckeetrails.org
- Sapphire
I dont really care what octane or oil I use... I am probably going to burn like 50 gallons of gas a year max.... when it comes down to $$ its going to be negligible... I'd just like to make sure its the good stuff!!
I guess I dont understand the octane thing either? Why does my truck get better mileage with 91 vs 86? What does the octane do to make it happier? I have no prob putting 87 in my bike if that is what it likes...
I am just waiting for the seller to calll... the dang 2150 is sitting iin my truck and ready to hand over!!!! Cmon phone...ring!
Thanks all!
Thanks all!
06' 200 Bone Stock
- Sapphire
- KDX4ID
>|QBB<[/url]
If the octane is lower at higher elevation then it's better for high compression motors?
Sapphire wrote:So...that graph seems to be saying...that at Sea level..it takes lower octane to make motors happy? Am I wrong? Actually..looking at it...it doesn't really say Chit...It shows 88 for Prem at 5500 and 91 at zero... but ???? What does it mean?
CURRENT FLEET
- Mr. Wibbens
My Vstrom gets less mpg with Super, but seems to run much smoother with Super
My DR650 ran better with Super
- Has thanked: 5 times
- Been thanked: 12 times
I dunno? I've never seen such a thing. I imagine that the difference in atmospheric pressure might affect the fuels stability. So at higher elevations the fuel is slightly less stable. Means practically nothing for real world application.
See my previous post, and don't try to over-complicate the issue. Higher octane fuels are needed in higher compression engines to prevent detonation, nothing more, nothing less. If your engine runs better on a higher octane fuel, it is either because the engines compression ratio requires it, or because you simply FEEL like it runs better with 92.
As for getting better mileage with a higher octane? Highly unlikely.
I'm only at about 1000 feet and if your gas works for you great I just know that premix does lower the octane level and with a single cylinder if I break it cause of bad gas and I'm 20 miles from the road I would be in a bad mood.
And as far as octane numbers they are there to show the fuels ability to prevent anti knock. The higher the octane number the better the fuels ability to control flame progression. The octane number is dependant on the premix ratio. For every 5 percent premix it takes off 1 octane number so not huge and unless we've had the head mod we prob won't have any issues but like I said I play it safe.
Also fuel loses its octane rating once it is over a week old and is reccomended to be used within a month especially premix due to the fact it brakes most oils down some more then others. As far as using regular gas in newer cars the reason it works is because of the computer and fuel injection sytem work in conjunction to keep the cars timing and fuel air ratio in perfect sync for the vehicles performance. I just. Notice better performance from the higher octane.
I notice a slight decrease in performance at 87 octane.... at 89 octane and above I notice no difference in performance. I have never been let down on the KDX due to gas.... I have ran year old gas before and it has worked fine... not preferred, just what I happened to have.
- Has thanked: 6 times
- Been thanked: 10 times
>|QBB<[/url]
Now, take a trip and ride in the mountains at 5500ft with all else being equal. With that same fuel you might encounter detonation, and the damage that results from it, due to the octane rating not being sufficient enough to control pre-ignition. You would need to step up at least one grade, possibly two, on your fuel's octane rating to keep your engine safe.
Well, at least that is how I read it.
What does it mean? IMO it means that as elevation goes up your octane rating for a given fuel goes down. Not a big deal unless you are jetted perfect for sea level. Prper jetting should have you close to the threshold of detonation (ie; pre-ignition) without actually crossing over into it.Sapphire wrote:So...that graph seems to be saying...that at Sea level..it takes lower octane to make motors happy? Am I wrong? Actually..looking at it...it doesn't really say Chit...It shows 88 for Prem at 5500 and 91 at zero... but ???? What does it mean?
- KDX4ID
What about the fact that there's less oxygen at altitude?
How does that figure?
CURRENT FLEET
I think I got that messed up just a bit. Eh, I'm so confused! LOL!
- KDX4ID
We know one thing... the KDX is not finicky about gas. One more reason to love her.
CURRENT FLEET
- Mr. Wibbens
try Toulene, its much cheeperjoshharris918 wrote:i use premium gas with motul 800 at 40:1. i also add a small bottle of octane booster to 5 gallons and it runs great i can deffinitly tell the difference.
