Installing FWW and Clutch Lever on kdx220
Re: 'I often wonder if...'
Hence, For Whom the Bells Troll
You did install a spacer under the cover?
Take the cover off..visibly check the wires coming from under the FW to ensure they are not damaged in any way.
While the cover is off, DO check for the presence of the key...look in the crank slot to SEE it...place a wire in the slot to FEEL it.
As long as I'm here...explain 'does not start' more completely. You actually kicked it a good bit? You have fuel..and you know that by tipping the bike on its side with the petcock 'on' to see fuel drain out the carb overflow hose? You don't have a rocker type 'kill' switch set to 'off'?
Unless you messed up a pretty good bit, there isn't anything to adding a FWW that will result in the bike not starting.
I DO suppose it started before? We're not going to end up with 14 pages of questions to arrive at, 'It didn't start before I put the FWW on, either. I thought that would fix it!'
- canuckhybrid125
Clutch cable,thottle cable,fww,KTM300,KTM200,I think juliend and I should have pretty much figured that out also.Tedh98 wrote:When I read the posts here and on TT, I often wonder if Byte is just a 12 year old just messing around with everyone.
It Is What It Is
2000 KX KDX Hybrid
2006 KX 100
2004 TTR 125 LE
2010 KTM 300
2000 KX KDX Hybrid
2006 KX 100
2004 TTR 125 LE
2010 KTM 300
Thanks Canyncrv.canyncarvr wrote:Re: 'I often wonder if...'
I tried kicking a great many times.
Bike tipped on side with fuel dripping out.
Rocker switch is not in off position.
Ignition cover and spacer removed for check - nothing untowards..
Yes, it did start before.
Thoughts?
Byte
A FWW will have an effect on the amount of rotation you get with a kick...although I doubt it's enough to make a big difference. I'm saying your starting sequence may need to change a bit.
May be you're fussing over a lot of nothing. You cannot effectively adjust the idle until it's good and warmed up..and that isn't going to happen after running for a minute.
As written...the bike started AFTER you 'reset' the fuel in the carb.
What you're describing sounds more like old gas...separated fuel (how long has it been sitting..and did you re-MIX the fuel in the tank?)..not anything related to the FWW.
Mix that fuel up..ride it.
What type of FWW did you use?
- Has thanked: 5 times
- Been thanked: 12 times
HAHAHA!!! I just love reading these posts on several different forums! Seems our buddy here also removed the carb and installed a new carb cap, throttle cable, and cable adjuster at the carb while installing the FWW.
Anybody else of the opinion that these carb related items would be more likely to cause a hard starting and high revving condition than the installation of a FWW?
Check your throttle cable and carb cap dude. And PLEASE try and give us all the info when you ask for help. It's usually good to do ONE thing at a time so IF (or WHEN in your case) you have a problem it's fairly obvious what caused it.
Pointless really.....
Please... one half-assed repair at a time.
Please...tell me you're kidding.juliend wrote:HAHAHA!!! I just love reading these posts on several different forums! Seems our buddy here also removed the carb and installed a new carb cap, throttle cable, and cable adjuster at the carb while installing the FWW.
This: 'Install of Accelerator Cable at Carb'
...was co-incident with the FWW 'problem;?
Thansk guys.
Yes - I agree I should be consistent when communicating the same message across multi-forums. (Sorry - it was very late at night when posting...tired)
Yes - new OEM throttle cable and OEM cap was installed at same time as FWW.
YEs - I agree 1 half assed repair at a time..
Yes - Oldish fuel used - I will remix a new batch today.
FWW - Steahy 10oz.
Byte
FWW - Steahy 10oz.
Byte
...and no mention of that when it comes to your bike not starting?Yes - new OEM throttle cable and OEM cap was installed at same time as FWW.
Maybe you think that's funny...seeing how much flailing and fussing you can get other folks to do in an attempt to help you out. If that is true, you are indeed a horse's ass.
But...I don't think it is (which is maybe even more hilarity for you).
...which is why I continue to bother with saying anything to you at all.
Still, you must do better. Indeed, one 1/2 fast 'fix' at a time. While it isn't necessary to include the air pressure in your tires...or the torque value applied to your front wheel spokes when relaying symptoms/problems with taking off a FW, it certainly is relevant to mention having the carb apart if 'hard starting' and 'hi idle' are part of your problems.
Chances of the throttle cable retainer being wrong are about perfect...and that being the case is why it is hard to start AND why it idles high. The tab on the white nylon retainer MUST fit in the slot of the needle retainer nut.
If you don't understand that...re-read it, study your service manual until you do.
Good luck.
........Resulting in hard starting and a very high idle.The plastic piece has a notch that fits into a groove in the slide. If it's not in there correctly the slide will not drop down in the carb like it should.
Byte-
How's that hybrid coming?
As I recall from some earlier questions...you had a kludged up mess of a cable..with no retainer, no clip on the carb cap tube.
So...you replaced all that stuff..and adjusted the freeplay in your throttle to...what?
Re: 'adjusting freeplay in throttle cable was not done.'
So...check it. I want to know what it is AND how you determine what it is.
ok.
There is one hitch and I know this will add another twist but I will tell you all upfront now...
After checking the carbi again late yesterday re retainer and re- confirming that it is aligned into groove of nut etc, I have decided to take whole bike to a bike mechanic to get this problem sorted.
Some (or all) of you will say this should have been done earlier but at least I have tried and I know my limits. there seems to be too many vairables on this particular issue (for me anyway)...
So, I am expecting the mechanic will check and adjust throttle (and whatever else) to ensure bike runs smoothly...
Byte
Byte
As tough as the learning curve may be...you don't learn a whole lot taking the bike to someone else.
Besides that...given MY experience with mechanics...after they 'fix' it, I have to 'REPAIR' what they 'fixed'.
Good luck!
Good luck!
