HYBRID DONE
- scheckaet
i have the same one and I think it's MSR from RMATV. So much better than the spaghetti stock.
Sold ☹ DRZ 400 SM
Sold ☹ DRZ 400 SM
To me and the way I like to ride the lighter weight and the lower CG of the KX makes my 1st Hybrid a blast to ride....
Hopefully my #2 will be just a bit better than the first one.
Rear suspension all mounted along with the forks, tires and rims ready too, just the small stuff mostly ..... I HOPE
#2 , 03 220 HYBRID..
Ha ha,
well it's a little bit of this and a little bit of that,
kinda a mixed bag of things im tryin to make fit and work.....
One problem is the motor thats still in my KDX that im plan to use.
Cylinder redone and then added a clutch kit later and picked up a viberation somewhere I haven't found yet....If I have to I may pull the motor from #1 and use it in #2 when I get it finished....
I'll have some pic's up when she's done......
- Tedh98
It's like with a lot of things, the 2nd time around you find better or different ways of doing something.THill wrote:Ha ha,
On #2 I put the ignition coil in a different spot. It was a small change but it made plug changes so much easier.
