Page 2 of 2
Posted: 09:16 pm Nov 29 2005
by Indawoods
FWIW... The circuit is holding up fine... no problems at all and the stock system keeps up with the LED tail/brakelight fine too!
I think you would need a relay to split the power with an additional VR to run the brake light completely separtately or you could modify what I have with additional wire but it would be messy.
It's up to you and really doesn't take a rocket scientist to mod the wiring but you must certaintly be careful or it could get expensive if you start frying components!
Re: Wiring your headlight switch
Posted: 02:38 pm Dec 03 2007
by blimpman
Do you still have the picture that went with this post? I am looking to do the same thing to my KDX220
>|QBB<[/url]
Indawoods wrote:Hey guys.. I came up with a circuit that allows you to control just the headlight with the lighting switch and keep the rest of the system hot. It took me a little while to figure out how the voltage regulator actually worked in their wiring but I have determined that there are no separate circuits at all in the wiring. When it goes live from the magneto, the voltage regulator puts anything above 12 volts to ground.
In this pic you can see how I got around their wiring to be able to use my brake light all the time.
The two wires to the right normally aren't connected together.
The yellow is from the magneto and normally goes to the headlight switch and the red one is the return and makes the entire circuit hot if fed.
To the left you see the switches wires (yellow and red) I have the red feeding into the hot on the headlight and the yellow going to the normal hot headlight feed. (Making the switch only switch the headlight)
The black ground wire is in the circuit as normal.
The tail light and brake light are alway hot on this setup. Mine is a LED setup so burnout is not an issue or so I hear and pulls very little current.
So... what do ya think? :razz:
Posted: 03:58 pm Dec 03 2007
by Indawoods
What are you talkin' about Willis? :mrgreen: :wink:
Posted: 10:02 pm Dec 03 2007
by blimpman
Well, the picture was DOA this AM when I looked at it.:oops:
OK now...
I am interested in the LED lights you used. Have Part numbers?
Willis has left the building. He is out back painting the bus. :mrgreen:
Indawoods wrote:What are you talkin' about Willis? :mrgreen: :wink:
Posted: 10:17 pm Dec 03 2007
by Indawoods
Just messin' with ya... I fixed the pics.... :lol:
I got the LED tailight from http://www.kevinscycleracing.com
Baja Designs LED tailight/brake light combo
But checking the site, I don't see the exact one I bought. Mine has a clear lens with clear LEDs that light up red.
You might call them and ask....
Posted: 10:26 pm Dec 03 2007
by Mr. Wibbens
Is that a BUTT PLUG?
Always seems funny when I see one of those
Posted: 06:05 pm Dec 05 2007
by tony_d123
Cool looking bike!
What rear mudguard have you fitted? Can't see any mention of it in your gallery.
