Another tip is to make sure your forks are perfectly straight up and down while doing this or else you will get a false reading.
Once you guys do this once.... your set for life.
If you happen to get too much oil in the tube... then this is when a suction device to take the extra oil out comes into play. I used a brake bleeding device. As seen in my gallery.
I actually measured and set the height I wanted by cutting the clear tube to the depth I wanted, added the oil, dropped the tube in and sucked the rest out. It was real easy.
