hart125 wrote:the 5/16 balls are the ones that drive the centrifugal system in the crankcase. I think the 3/16 ball is the one we are talking about on the left side of the power valves on the cyl.
I had more pressure on mine by removing one washer and I noticed that the transition was more abrupt.. you could tell when the power valve opened. Obviously it opened at a higher rpm also with more pressure but also it closed at a lower rpm. more pressure means the valve stays in its position longer. More pressure means less predictability IMHO
Thanks for the clarification about "balls" . . . I was indeed discussing the system in the crankcase.
I put a little more thought into it then ordered one of the springs (the one in the crankcase). I'll use it for reference for a stiffer spring then either find a "weaker" spring or snip a tad off the new stocker.
Looks a little involved to make the change but I should be able to handle doing it twice. . . actually that would be three times unless I stick with the last one
Plan: after each "setting" is in place (stock, then stiff spring, then weak spring) I'll remove the cover off the left side of the main shaft for observation purposes, use a tach, and monitor KIPS movement. If I can manage to get the tach within the "view" of a video, I'll record the results. Then seat of the pants.
It's conceivable it ends up being a bunch of work with unexciting results, then again . . .
I must be crazy
