Page 2 of 2
Re: 91 200 progress
Posted: 02:31 pm Mar 26 2023
by JZ05220r
Took it for its first break in ride today. And it ran awesome. It was a bit lean on the bottom.. alittle “bog happy. But over 1/4 it ran beautifully and sounded nice and crisp. Running a 36mm pwk from a 220/200. I’m going to go up a size on the pilot to a 48 or raise the needle a clip. Other than that it was problem free. I checked the cylinder head temp after my 15 minute ride around a field and it read way too high at 400 degrees F. Then I realized my infrared temp gun was way off. My skin temp was 220 degrees F, boiling water was 700 degrees F, and some room temperature glass was -10 degree F according to my infrared temp gun.
thank you guys
Re: 91 200 progress
Posted: 03:29 pm Mar 26 2023
Sweet! except for that temp gun :-)
Re: 91 200 progress
Posted: 07:01 pm Mar 26 2023
by JZ05220r
KDXGarage wrote: 03:29 pm Mar 26 2023
Yea that scared the crap out of me. I ended up getting rid of the bog after the first ride. I went up on the pilot and up a notch on the needle. I haven’t dialed the air screw just yet but I think going up on the pilot was unnecessary because after idling it just outside the garage I noticed a fairly strong unburnt gasoline smell. I also started noticing coughing/backfiring when I kicked it a few times and it also coughed when I killed the engine on one occasion. It never kicked back. Sound right?
Re: 91 200 progress
Posted: 12:22 am Mar 27 2023
Get it warmed up before touching the air screw. Just get it and the pilot sorted before going up to needle and main.
Re: 91 200 progress
Posted: 10:56 pm Mar 27 2023
by JZ05220r
KDXGarage wrote: 12:22 am Mar 27 2023
Got it pretty dialed in with the 45 pilot, and using the r1173n needle 4th from top, and a 155 main at 40:1. No spooge. It bogged off idle with the needle on the 3rd clip. Lowered needle one notch and the bog got much better but still there right off the bottom. I’m thinking I could go a bit more rich because the carb im using (H series bored to 36mm) has a needle jet that sits 2mm higher than standard. Really doesn’t smoke much at all unless I am warming it up with the choke on.
Re: 91 200 progress
Posted: 06:05 pm Mar 28 2023
by JZ05220r
I tried a cek needle I had lying around while leaving the rest of the carb circuits untouched so 155 main, cek 3rd clip, and 45 pilot. I got rid of the bog completely with this set up but rpms took noticeable longer to rev out past half throttle. I went down to a 152 and that didn’t help. I’m thinking I’ll go back to the set up above but try to run a 48 pilot instead. A lot of this ramble is to keep record but I will definitely take suggestions. Thank you
