Page 2 of 4
Re: 1988 KDX200 build thread : The gift that keeps on giving (me headaches)
Posted: 10:34 pm Sep 07 2020
Ha ha. It can develop like that!
Posted: 01:08 pm Oct 04 2020
by TheGarBrah
Little bit of an update on the Build:
I managed to source enough spare spokes and nipples from a fellow KDX enthusiast on ebay to continue forward with the project. I decided to try wire wheel and polish each of the spokes and nipples since I had already started down that road. **WARNING** do not ever try and attempt that because it is a huge time suck and can be endlessly frustrating. Better off just buying all new spokes and nipples or for that matter just get new rims. I did save some money but I probably spent more time than I should have and lost money in that area.
Removing old rusted bearings has got to be one of the most frustrating, time consuming, and lack luster parts of a build that I can think of. There is zero glory in it and it just feels like you are a complete idiot when the damn things won't come out. I had to "manufacture" some of my own tools and devices for the project because using punches, hammers, an blind bearing pullers just wasn't working too well. I would definitely suggest soaking the hubs in a tub of WD40 or penetrating oil overnight and then using heat on the hub if you think that the bearings might be rusted. These KDX hubs can be a real struggle...
I also ran into an issue putting on the clutch cover where I decided to try and use my press to "gently" put it back on the last bit of the way and cracked the case. I attempted to patch and conceal the crack only to have it split even worse when I was tightening the bolts down the next time I tried it. Looks like now I have to buy a new clutch cover or have a welder repair it. Either way its a huge PITA and was a real motivation killer.
Hoping to have this thing on wheel soon and hopefully have the engine on the frame. The last part of this will be finishing up the original seat and trying my hand at coming up with a decent paint job using spray cans. I know... spray can jobs don't look good on plastic. But I've done enough research and had enough success in the past to where I think I can actually pull it off and am more curious to see how it turns out.
Posted: 01:18 pm Oct 04 2020
by TheGarBrah
more photos
Posted: 11:18 am Oct 05 2020
Lots of fun!
I hope you chunked that rim onto the recycle pile. :-)
Posted: 02:08 pm Oct 08 2020
by TheGarBrah
I actually decided to keep the rim since it didn't seem to have structural damage, I shaved the broken bit down and reinforced the section with metal filler. If it cracks then oh well.. more curious to see how this things holds up. I'm trying to see how to keep costs down while on this project since I just keep running into issues that are getting more and more expensive and I've still got to deal with painting the plastics and doing all the electrical components.
This thing should be a legit rolling chassis very soon, and I'm getting excited to finally at least have all the skeleton buttoned up and then be able to focus on the motor and cosmetic stuff.
Posted: 04:23 pm Oct 08 2020
That is right by the rim weld, which has a crack on each side. GULP!!
Have you considered sanding the plastics and buffing them out instead of painting them?
Posted: 01:50 am Oct 14 2020
by TheGarBrah
I have sanded the plastics and and tried buffing, but the coloring is not uniform and it looks off. I'll probably do a detailed documentation on that part of the build. But for now I'm just trying to get this thing put back together and then I can focus more on the looks and getting into the details.
As for the rim, I know that its on borrowed time. Won't be doing anything too wild on this bike for the time being and I'll probably upgrade both rims after this is all back together. But for now it is what it is.
Posted: 12:10 pm Oct 15 2020
by TheGarBrah
Just to give some idea about the condition of the plastics. The gas tank has been sanded down to 80 grit and I did a light bit of buffing on with the scotch brite pad. The different is minimal and I don't think the pad is going to cut it.
The front fender was painted with a spray can duplicolor engine enamel green once upon a time back in the early years of this build. The result was pretty damn good IMO considering there was not much prep effort put in and just adhesion promoter, primer, and the paint with clear.
This time around I plan on using SEM specific flexible primer , along with evercoat flexible filler to patch up uneven spots, and sealer. I'll probably go with a JP kawasaki green spray color and then finish it all off with Spraymax 2k clear coat gloss.
If it looks halway decent and shiny I'll take it as a win. I don't think spending hours on the polishing wheel or attempting to buff these plastics is going to look good or be worth the time.
I could always buy new plastics but... The thread is titled as such for a reason. I'm a glutton for punishment.
Posted: 11:39 pm Oct 15 2020
You might want to watch the youtube video of the guy working on a red tank. He started with 220, then went to finer and finer grits.
Posted: 07:31 am Oct 17 2020
by lucy
As an initial step, I have used a razor blade to scrape off the outer plastic surface with excellent results. Just have to lean the blade backwards a little so it scrapes and doesn't cut into the surface. You gotta' get all that white oxidation off.
As K-Gar proffered, using progressively finer grit paper will get all the sanding marks out. My final effort included wet sanding with grits as high as ?1200(or higher). Then hit it with a heat gun(carefully) for the final polish.
Posted: 12:44 pm Nov 28 2020
by TheGarBrah
As far as the plastics goes, I've tried to the sanding and heat gun technique with poor results. These plastics are so bad that it would be almost impossible to get them looking uniform. The heat gun does work but has a tendency to be uneven and can cause melting very quickly.
Posting some updates on my build. Finally got the engine put together and new piston in. Had some issues waiting on various parts and pieces that were missing . Will be installing the engine back on the bike over the weekend. Sending my flywheel and stator off to FRP racing because the magnets had fallen off the original . With regards to the rear brake guard does anyone know how it should be attached ? It looks like it needs a spacer or maybe mine is bent ?
Anyone know if there should be a spacer here ?
Ordered materials for painting the plastics and I've already laid down the primer coat on them. So far I'm real impressed with the SEM flexible primer and I'm planning to be using the Evercoat polyflex to fill in any gaps and surface imperfections. Base coat will be PJ1 Kawasaki Green and I'll be using a Spray Maxx 2k clear .
Posted: 07:25 pm Nov 28 2020
Looking good. Here's a pic of someone who did an Armor All restoration.
EDIT ADD ON: Please note that the bolt head hits the top of the brake pedal, not the end of the bolt as the Armor Aller did. :roll:
Posted: 08:42 pm Nov 30 2020
by TheGarBrah
Thank you for picture KDX Garage . I've seen the exploded view diagrams and just wondered why I was seeing a gap between the portion on the top. It occurs to me that my bike may have the wrong part or a part from an earlier year...
Posted: 12:19 am Dec 01 2020
Oh yeah! Some previous owner / Mr. Goodwrench may have "laid hands on it".
Posted: 02:23 am Dec 03 2020
by TheGarBrah
KDXGarage whose bike is that or where is that pic from ? Looks like a pretty clean motorcycle and similar to what I'm building
Posted: 01:20 am Dec 04 2020
Someone on the internet trying to sell one, might have been an old picture. They were talking it up, but it has a gallon of Armor All on it.
Posted: 08:22 am Dec 05 2020
by Goofaroo
Here’s a couple of pics of my 87. You’ll have a lot of fun with yours when you get it done. Mine is stock other than a shock revalve and has been extremely reliable. It also draws a lot of attention on the trails. Everyone seems to have fond memories of these old bikes.
Posted: 03:59 pm Dec 08 2020
by TheGarBrah
Nice Bike Goofaroo !
Quick question, does anyone know of any good rear chain slider options for the swingarm ? I can't seem to find enough info on what might work . Can I get one that fits on another bike like a KX and have it work ?
Posted: 06:45 am Dec 09 2020
The one in front of the sprocket, at the bottom? frpoffroad.com He has made those plates for 30 years almost.
Posted: 03:57 pm Dec 14 2020
by TheGarBrah
No I meant the sliders that fit onto the swing arm . I don't know if they are all fairly standard of if the 88 kdx has some special requirement. Seems like this year every darn part on it is "unique" and "special" :rolleyes:
