Page 2 of 2
Re: Cooling advice
Posted: 08:45 pm Mar 12 2020
by Kdxfan4130
You can smell it when you have a combustion chamber leak into the cooling system too just sniffing the radiator cap opening.
Try running one step cooler on the spark plug. Run the highest octane fuel available. Get a higher rated radiator cap as mentioned earlier. Not sure what bar the kdx radiator cap is.
Kawasaki radiator caps
49065-1070 1.1 bar
49065-1073 1.6
49065-1077 1.8
Re: Cooling advice
Posted: 02:45 pm Mar 13 2020
by doakley
kdxdazz wrote: 06:50 am Mar 12 2020
This is my Chinese radiator and the second photo is OEM radiator from a Klx250. Even though they are of very similar dimensions the Chinese radiator has 9 cores and the OEM has 17 cores. This would make a huge difference towards cooling efficiency. Can anybody confirm how many cores the OEM Kdx220 has
Looking at the photo in my Cyclepedia KDX manual (you DO have a manual, right?) it shows 13 rows of fins. I'm guessing that's what you mean by "cores"?
Re: Cooling advice
Posted: 03:54 pm Mar 13 2020
1997 KDX220-B4 radiators are the same part numbers as 1995+ USA models.
Re: Cooling advice
Posted: 03:10 pm Mar 17 2020
by Pressingonward
I would skip the computer fans and run a 4" Spal. Waterproof and has far more air output.
I work for Trail Tech and we make a universal fan kit that would do the job nicely. There used to be a couple other players in the market, but I think they've gone out of business. It'd be easy enough to piece together your own system, but find an industrial or automotive grade fan that puts out some decent airflow. I think the 4" Spal fans are 148 CFM iirc
Re: Cooling advice
Posted: 07:26 am Mar 18 2020
by kdxdazz
Pressingonward wrote: 03:10 pm Mar 17 2020
A proper fan would be a help but it's not the main cause of my overheating as the temp light will come on just riding around on the road. Daytime temperature here is 40 degrees Celsius. Still convinced it's the Chinese radiators but I could be wrong
Re: Cooling advice
Posted: 08:26 am Mar 18 2020
by Pressingonward
Ah. Missed that point. If you are above 5-10 mph and it's getting hot then yes, I'd probably suspect the radiators as well. You could pull them off and check the flow through them with a garden hose
Re: Cooling advice
Posted: 08:57 pm Mar 18 2020
by kdxdazz
Pressingonward wrote: 08:26 am Mar 18 2020
When I bought the bike the radiator cores were blocked, I had the tanks taken off then I personally went through every core with a hacksaw blade to clean them out. I tried running slightly richer jetting to cool it down but didn't seem to help. I'm going back to Australia next week so I will look at picking up some radiators from a big bore 4 stroke and modifying them or get a custom made set here in Thailand
Re: Cooling advice
Posted: 10:38 pm Mar 18 2020
by bufftester
The interior passages may be partially blocked. A flow test will indicate that. Or they may just be of inadequate size and number for this application.
