Page 2 of 2
Re: KDX220, new to me
Posted: 10:58 am Mar 12 2020
by rtbmrgl
javjacob wrote: 10:03 pm Mar 08 2020
Very nice!!! A good motorcycle suspension shop can rebuild that rear shock. For the gas tank check out plastex.net
https://www.plastex.net/
I have used it to repair many plastic parts and it works great.
That looks like Q-Bond, which I think is sodium carbonate or sodium bi-carbonate and super glue. Works great.
Watched there video, looks like good stuff.
Posted: 05:47 pm Mar 12 2020
by rtbmrgl
The 220 is done, runs good other than about 1/4 throttle,
Idles fine and just off idle. 4 strokes at about 1/4, 1/3 throttle on runs great.
Only mods are Boyesen reeds, FMF desert pipe and snorkel removes.
Stock jetting,
Main-145
Pilot-42
Needle- R1173l
Air screw- 1.5 out
Any suggestions
I tried raising and lowering the needle 1-up and 1-down no difference
I do have a 35mm from a 200 to try.
Posted: 08:42 pm Mar 12 2020
by javjacob
Looks awesome!
Posted: 08:47 pm Mar 12 2020
by rtbmrgl
javjacob wrote: 08:42 pm Mar 12 2020
Looks awesome!
Thanks, just need to get to jetting a little better.
Posted: 09:01 pm Mar 12 2020
by Kdxfan4130
Plug looking rich you might try one smaller pilot jet. Especially if your needle clip is in the upper 2 clip settings. You didn’t say where the clip is currently, not sure what four stroking is. I’ve found blubbery sluggish is rich, to lean it runs too good zingy quick revving puts a hole in the top of the piston.
Nice kdx holy moly!
Posted: 12:01 am Mar 13 2020
by rtbmrgl
The was in the middle position, I raised and lowered it one clip, didn’t seem to make a difference. 4-stroking, running rich. I’ll try smaller pilot jet.
Posted: 12:29 am Mar 13 2020
Keep a thicker needle in mind.
It looks great!
Posted: 11:21 am Mar 13 2020
by rtbmrgl
KDXGarage wrote: 12:29 am Mar 13 2020
It looks great!
Thanks, I tried a 1174 needle, and didn't seem to make a difference either.
My jetting will be put on the back burner, my March trip was canceled.
In lieu of what I have been reading about cracks in pistons. I'm taking the cylinder off and replacing the piston.
Posted: 02:38 pm Mar 13 2020
by doakley
Before you start changing jets, make sure the air screw is set correctly for what you have. Just a suggestion.
Posted: 02:48 pm Mar 13 2020
by rtbmrgl
Well I removed the cylinder, and found the plating is coming off between the exhaust port and the top of the cylinder. So I guess sending it to be re-plated is the answer. Where is a good place for re=plating.
Posted: 03:49 pm Mar 13 2020
Millenium or PowerSeal
For example:
viewtopic.php?f=77&t=24041#p206710
Posted: 05:25 pm Mar 13 2020
by javjacob
Millennium is the best.
Posted: 06:39 pm Mar 13 2020
by rtbmrgl
Thanks, I called Millenium,
Posted: 03:43 pm Mar 15 2020
by Twinsig
If you want to save a few bucks on a new piston send me a PM.
Posted: 11:40 am Mar 18 2020
by rtbmrgl
Twinsig wrote: 03:43 pm Mar 15 2020
Thanks, I actually bought a Wiseco, I sent it off to Millennium with the cylinder.
I didn’t see a PM link on you profile.
Thanks anyway.
Mark
Posted: 12:29 pm Mar 18 2020
Posted: 12:31 pm Mar 21 2020
by VTMTcowboy
rtbmrgl wrote: 05:47 pm Mar 12 2020
Stock jetting,
Main-145
Pilot-42
Needle- R1173l
Air screw- 1.5 out
Any suggestions
Beautiful bike and outstanding find! I am out in Napa if you ever want to ride. I ride Foresthill mostly but I am open to wherever. Take care.
Posted: 09:39 pm Mar 26 2020
by rtbmrgl
Got my shock back today, $110 later, new seal, oil, gassed up and ready to go.
