220 run away
- Country: Usa
Re: 220 run away
Well I put the spare carb on with the same result. So that’s not it. I made sure the piston was at the bottom of its stroke and pressure tested again. It held the test. Guess I’ll try to pull the reed block so I can get a vac test on it. Grasping at straws here.
- Country: Usa
Re: 220 run away
I’m a little embarrassed to admit this but in the interest of full disclosure and hopes no one else suffers through this I’m gonna fess up. Pretty sure the throttle cable was the culprit all along. One of my first moves in diagnosis was to remove it from the grip. Unfortunately I didn’t inspect under the cable dust protector. There the cable was damaged. I worked it strait and the idle came down. Finished for tonight but I think we can call this one solved. Thanks for all your help guys.
Re: 220 run away
SWEET!
Got it solved, which was the main goal.
- Tyl3r
Re: 220 run away
Hah! Always better to be wrong about a cheap part than right about an expensive one!
- Molly's 70
220 run away
My KDX runs great! However, I ordered a couple of these jet block gaskets just to have it on hand. I replaced mine anyway. I had never even heard about the jet block gasket. I'm old, worked on plenty of motorcycle carbs. I learn stuff here. Lots of good KDX stuff. Thanks to all!
Re: 220 run away
Hi, not sure if anyone mentioned that you need to replace the throttle cable with a stock one, not a aftermarket one! The aftermarket ones don't have the bend/carb boot to seal the cable at the top of the carb.
- Tyl3r
Re: 220 run away
Glad you got it figured out! I know ran into problems before similar to that with the little white plastic piece on the spring not fitting into the groove in the slide correctly. Took me a minute to figure that super simple thing out too
Re: 220 run away
Motion Pro throttle cables have the flexible boot at the end just like the stock one.jjavaman wrote:Hi, not sure if anyone mentioned that you need to replace the throttle cable with a stock one, not a aftermarket one! The aftermarket ones don't have the bend/carb boot to seal the cable at the top of the carb.
